Tansmission fluid ckeck 2001 s40
Old Dec 29, 2005 | 10:59 AM
volbah's Avatar
Default Tansmission fluid ckeck 2001 s40
Hi im a volvo novice. Where is the transmission fluid dipstick on a 2001 s40 1.9T located. At what intervals should the fluid be changed? What type of fluid should be used?
Old Dec 29, 2005 | 05:37 PM
Black Beauty T4's Avatar
Default RE: Tansmission fluid ckeck 2001 s40
Hi. I'm assuming that you're talking about an automatic tranny.
The dipstick is located in a tube at the front of the engine (NOT the dipstick handle that is marked "Engine" and/or "Motor").
After driving the car for several miles (gearbox fluid needs to be at normal temperature i.e. hot), park on very level ground, put the shifter lever into every position & leave it there for several seconds before moving to the next position, then finally into Park. Leave for a couple of minutes then, with the engine still running, check the fluid level in a similar manner to the way you'd check engine oil level.
Fluid should not appear "dirty" - if it does then get your dealer to flush the transmission ($$$!).
If near the "min" level, switch off the ignition & top-up with Volvo's own fully synthetic automatic transmission fluid (they'll advise you which one, depending on whether you have the 4 or 5 speed version - 5 speed for that year I think), taking care not to over-fill.
Regards.
BB
[sm=icon_cheers.gif]
rportulano
May 29, 2013 09:36 AM
grodri1972
Mar 20, 2013 10:23 AM
CoolDogz
Jul 5, 2010 11:43 AM
bigvolvo
Jul 29, 2009 07:38 AM
revhrd
Apr 7, 2009 08:31 PM
