Tansmission Compatability/Sensor Issue
Old Mar 23, 2009 | 02:55 PM
revhrd's Avatar
Default Transmission Compatability *UPDATE*
I have a 50-50SN (per transmission plate) transmission that is already in its last legs. What transmissions are compatable with this car.
2000 S70 2.4 Non-turbo, automatic.
I saw one on ebay but I do not know if it makes a difference, I know with certain models there is a difference in trannys due to turbo, non-turbo, 4 speed at, 5 speed at...
Please help...
Thanks,
Dave
Old Mar 23, 2009 | 09:40 PM
revhrd's Avatar
Guys I could really use some help here...
Old Mar 23, 2009 | 10:04 PM
TIPSP's Avatar
Got Boost?
Tech...any thoughts?
Old Mar 24, 2009 | 09:45 AM
revhrd's Avatar
I called my local dealer here in vegas, but they said they "couldn't" help me over the phone that I would have to go in, leave the car, and basically have them do the work...
I can do the work, just trying to figure out the truth, I also found out that it has to be the exact transmission, same year, same model, same features otherwise the transmission would not fit and/or the transmission ecu would not register it and render the car undriveable...
thanks in advance guys...
Old Mar 25, 2009 | 09:44 PM
revhrd's Avatar
No one?....
Old Mar 26, 2009 | 07:08 PM
I believe the tranny is a AW 55-50/51SN.
I believe the tranny's are the same from 1999-2002 I believe.
You might have to swap the tranny harness from yours to the tranny.
But I have put different year tranny's in with no problems as long as it is from 99 and up.
Old Mar 27, 2009 | 10:57 AM
revhrd's Avatar
tech,
thanks for taking the time to help me out. I came across a 1998 s70 tranny... In your experience this year is NOT compatible correct?
thanks,
dave
Old Mar 27, 2009 | 07:21 PM
I would say no it will not work. That I believe is only the 4 speed tranny and yours is a 5 speed.
Old Apr 5, 2009 | 11:57 AM
revhrd's Avatar
Update...
I got a 2001 transmission from a wrecking yard locally, they had to bring it from UT. Anyways, I swapped it out yesterday, installed the new pnp switch I had in the bad transmission (i had installed a month ago in hopes that the transmission did not have irreversible damage), changed the fliud on the tranny...
No good... Flashing arrow still on, now it engages/disengages in forward and backwards drive (old tranny did it only in reverse but was stuck in 2nd or 3rd going forward), it struggles past 2k rpms like it looses power off and on till about 30mi an hr were it seems a little bit better...
I hope I can find some advice from you guys before tommorow...
The only scenarios I can think of:
1- I did not properly adjust the pnp switch (dealer visit)
and
2- I need to have the transmissions codes fully erased (dealer visit)
or
3- transmission that I installed had this problem as well...
Any help is greatly appreciated...
Dave
Old Apr 5, 2009 | 11:59 AM
Yes the PNP might not be adjusted properly.
Also the codes need to be cleared.
Old Apr 5, 2009 | 06:56 PM
revhrd's Avatar
Tech,
Thanks, I will take the car to the dealership, I searched in the posts an I think that the cost is about $150 for pnp adjustment and another $65 to delete the tranny codes. Does this sound right?
Thanks,
Dave
Old Apr 5, 2009 | 07:03 PM
IMO it should cost less to do it. But they might charge you that.
Old Apr 7, 2009 | 07:57 PM
revhrd's Avatar
Well a trip to the dealer... $360 later... success!!! it runs great.
Thanks for your help tech...
Old Apr 7, 2009 | 08:31 PM
Glad all is good now!!!
rportulano
May 29, 2013 09:36 AM
grodri1972
Mar 20, 2013 10:23 AM
CoolDogz
Jul 5, 2010 11:43 AM
volbah
Dec 29, 2005 05:37 PM
dc_slim
Sep 6, 2005 09:49 AM
