What to do R.i.p. kit or samco hoses or custom
well im confused on what to do. i know my 1997 850 t5 should get the hoses replaced but what is the best route. should i get the ipd rip kit. go with the samco hoses or do a custom front mount. i plan to keep mods fairly simple on the power plan on getting the idp stage one ecu and a k&n filter and maybe an exhaust.
so what does everyone think i should do
another question. does the samco hose kit just replace the rubber parts and connect to the stock aluminum pipes
thanks in advance
thanks in advance
the samco is just as you said. replaces the stock rubber.
IPD RIP kit. only porblem is that it lets more oil into the motor.
FMIC is the way to go. can be done pretty cheap too.
If you are going to get an ipd upgrade ecu. do the exhuast (3" turboback) filter, or CAI, FMIC, and the then do the tune.
http://www.turbo-tuner.co.uk/ttusb.htm
here is a link to turbo tuner
im leaning towards the obx or custom if i do custom it will be 3 inch but wont be a straight through design muffler in case i have to take the car on trips. interior resonance is a huge thing that bothers me i like to be able to hear myself think while i drive
Well if you want the most power then a straight through muffler is what you'll want. Also you could do two mufflers and or a resonator.
I would go the full silicone hose route before doing a rip kit. The whole intake system is already very effective, and like said earlier, the rip kit mostly aesthetics. I remember you said that your going to be coming to the midwest meet in August, I have a turbo back OBX exhaust, 3" DP to 2.5" exhaust straight pipe (no cat), and you can hear how it sounds, it's actually not very loud at all and I am very pleased with it, nice tuned sound. I have that with a K&N box filter and like the improvements. There are noticeable gains with the exhaust, faster spool up times.
guest01
07-25-2014 08:41 AM
T5Nightmare
04-12-2010 08:33 PM
