Volvo C70 Auto gearbox fault
Old Jun 27, 2007 | 01:18 PM
matthew@xpress's Avatar
Default Volvo C70 Auto gearbox fault
Hi can anyone help. I have just bought a C70 coupe 2.3 turbo.When I drove it gently it was fine, whenI accelerated harder I lostdrive & reverse.I would have to stop turn off engineleave the car for 10 minutes start up drive again. I had it scanned for faults and nothing was recorded in the ecu. I changed the gearbox and still the same happens only it is worse now. Any suggestions would be great. Regards Matthew
Old Jul 5, 2007 | 07:14 AM
JPN's Avatar
JPN
Default RE: Volvo C70 Auto gearbox fault
Hi Matthew,
I'm sorry about the problem, it must be annoying & unsafe to drivethe caras it is.
If swapping the gearbox didn't solve the problem and no fault was recorded in the ECU, all I can think of at the moment is that someone may have introduced the wrong type of transmission fluid. Older Volvos use Dexron-III/Mercon, but newer Volvos seem to use completely different types of fluids. Or, there may have been manufacturing defects, did you check for recalls? It could also be mis-adjusted shifter linkage, low fluids, etc...
Post this question in the C70 forum; I believe people there can help you better than I could, as I'm an 850 driver.
I wish you the best of luck resolving the problem.
JPN
bongo dave
Feb 12, 2010 04:23 AM
mac1983
Jun 19, 2009 12:36 PM
lilkarencita
Aug 4, 2008 06:28 PM
matthew@xpress
Aug 16, 2007 07:14 PM
MATTHEW@XSM
Aug 15, 2007 05:59 PM
