Penta Discuss Volvo Penta Marine Machines Within.
Penta D6-370 shut-down
Old May 18, 2024 | 02:48 PM
Barsballe's Avatar
Default Penta D6-370 shut-down
I have D6-370 from 2007 with 1000 hours run-time.
i have two cases of sudden shut-down of engine when running at cruise speed. It happened after sailing 3-4 hours at low speed, and 5-10 minutes after acceleration to Cruise speed the engine suddenly stops completely. Engine cannot start after shut-Down, however after 30 min standstill it starts perfectly.
it is not blocked diesel pipes, but Volvo dont have an answer.
Have anyone experienced this, and found the defekt?
Old May 26, 2024 | 10:32 PM
Niklas11Braun's Avatar
First, look at the cooling system since overheating can make the engine shut down. Check for leaks, radiator blockages, or problems with the thermostat.
If the engine starts fine after sitting for 30 minutes, there might be a problem with the engine's electronic control module or sensors.
Also, check fuel injectors, fuel pumps, and turbocharger for any wear and tear. This can cause the engine to lose power or shut down unexpectedly, especially when you accelerate.
Old Sep 25, 2024 | 09:11 PM
Harry125's Avatar
Default Any updates on this issue? I have the same problem with starboard engine
[QUOTE=Barsballe;531508]I have D6-370 from 2007 with 1000 hours run-time.
Old Sep 25, 2024 | 09:35 PM
Harry125's Avatar
Also , there is a yellow triangle warninglight and the text ved man inst what I think means look into manual instruction but doesn't say what or where. Doenst look like overheating or any differences to the Port engine. Operates normal for hours and suddenly shuts off completely. Restart after 1 min completely normal but ⚠️ stays on. Clueless 🙈
Bricklover
Mar 12, 2019 11:06 PM
StefL
Nov 1, 2018 02:26 PM
mcewena
Sep 2, 2016 12:50 PM
louiebay
Apr 7, 2014 12:00 PM
magoo0903
Nov 17, 2009 11:01 AM
