Penta Discuss Volvo Penta Marine Machines Within.
V6-200-G Hot start and Rough Idle issue
Old Jun 1, 2022 | 11:33 PM
mateosau's Avatar
Default V6-200-G Hot start and Rough Idle issue
Hi Guys,
I have a 2016 v6-200-G that is having a starting issue.
Water and engine temp come up to operating temp fine. (No longer overheating due to air being sucked up from leg.)
After a while, if i turn the engine off, it struggles to start and sometimes will not start unless I let it cool down for 30min. Once started, Idle is rough and will die if left alone.
This issue is reproduceable while on the trailer and muffs.
I'm using a fuel pressure tester on the carter high pressure pump. I don't know what it should be so I don't know whether there is a problem here. This engine has two high pressure pumps. The one from the carter fuel pump module and a GM one as the block is from a Chevy Silverado.
The tester is reading 80psi and bouncing around +/- 5psi at idle and at 2000rpms from the carter pump.
Video of pressure
Blackmax
Penta
Oct 7, 2020 10:50 AM
Elimakov
Jan 17, 2020 10:17 PM
huey3110
Dec 16, 2016 06:06 AM
abigweasel
May 18, 2011 05:55 PM
j1911e
Sep 9, 2010 04:51 AM
