14mm or 16mm Tie Rods? 1994 Volvo 940 T
Old Jun 10, 2011 | 04:36 PM
FlyingVee's Avatar
Default 14mm or 16mm Tie Rods? 1994 Volvo 940 T
This is not an entirely new subject here. My understanding from what I have read to date is that the boot covering the inner tie rod can sometimes be inscribed with a code representing the size of the tie rod thread. This however cannot be relied upon.
It has also been said that this information is contained on the VIN plate. On the second row down at the right side of my plate is the code 16(240 2). Nowhere else do the numbers 1 and 6 (16) or 1 and 4 (14) appear together.
Can I take it that my tie rods are most likely 16mm or should I measure them to be sure? I am erring away from this as I don't know if they are exposed and.. ahem I am not yet sure how to measure a thread (caliper gauge across the breadth of it?)
Thanks for your thoughts.
Old Jun 12, 2011 | 09:33 AM
Typhoon's Avatar
The sure way is to find out which make of rack is in the car. To read thread diameters, it is the OUTER diameter of the threads, that is, the overall diameter to the outer edges of the thread.
Old Jun 13, 2011 | 06:06 AM
FlyingVee's Avatar
Default Thread Diameter of Tie Rods
Thanks Typhoon. I think I have been labouring under a misapprehension having got the wrong end of the stick from a q & a here (ntm a jumpy mechanic here).
The thread size was treated as such a mystery I thought they must be referring to the inaccessible thread connecting the tie rod to the steering rack. Are you saying it is the thread where the inner tie rod connects to the outer one?
fredbyte
Apr 20, 2009 07:02 PM
myfakename
Feb 22, 2008 01:23 PM
buckquark
Oct 29, 2007 10:47 PM
SDozier
Jun 27, 2006 12:40 AM
EBITDA
Nov 8, 2005 09:14 PM
