150 kPa cap
Old Jan 25, 2016 | 08:53 AM
jurob's Avatar
Default 150 kPa cap
Is it ok to run a 150 on my 86 245?
It was building any pressure so I borrowed the cap from my 94 945 which is 150. The 245 was a 75.
It now has pressure in the coolant hoses.
Couldn't find a 75 locally.
Old Jan 25, 2016 | 09:52 AM
tryingbe's Avatar
It's fine.
Old Jan 25, 2016 | 03:26 PM
lev's Avatar
lev
I'd get the right cap. May be the cap you had was bad. But a 150 cap would keep much more pressure than a 75lbs cap before releases--may be unhealthy. I tend to follow Volvo's recommendations when in doubt.
Old Jan 25, 2016 | 07:59 PM
brickrunner's Avatar
It is not ideal and I would only use it temporarily until I get the correct one. With that said, I see Volvos pictured on the internet all the time with the wrong caps and they seem to be running fine and with them.
Old Jan 26, 2016 | 06:16 AM
act1292's Avatar
Yeah - but if it runs too much pressure and end up blowing a hole in an aged heat exchanger - oh what a job!
Old Jan 26, 2016 | 08:05 AM
jagtoes's Avatar
You've got twice the pressure for a system designed for half. Nothing good can come out of it. Go order another cap. What does the 75 KPA cap do. Does it blow off coolant
pinky
May 13, 2010 02:44 PM
silkhope
Sep 5, 2009 10:07 PM
gildorluthien
Jul 29, 2009 03:35 AM
jeff201865
Jul 26, 2008 09:38 AM
Moose
Apr 13, 2007 06:51 AM
