1981 240 wagon sputters only in cold weather at high speed
Old Nov 3, 2012 | 06:45 PM
oldskoolbrick's Avatar
Question 1981 240 wagon sputters only in cold weather at high speed
This is my 1981 240 wagon GLT 4 speed + OD. My question is: What causes the engine to miss? (more info below)
So It's got a miss that I noticed, but didn't seem like a big deal. It's been more of a problem lately. It's like the engine shuts off for a moment, then springs to life briefly, then it repeats. Not consistently though, more or less randomly.
Accelerating from a stop is fine, until I'm cruising in cold weather for a minute or so. on warm days it's happy as can be at any speed for any amount of time.
Any ideas?
Old Nov 4, 2012 | 09:26 PM
I'm going to attempt to capture it on video. Anyone interested in a Video of this thing missing?
Old Nov 5, 2012 | 09:58 AM
possibly a clogged fuel filter, or weak fuel pump(s). If its temp specific, i'd hazard to suspect the fuel pump, maybe the in tank pump is sketchy.
thats a CIS (K-Jet) car, right ? so no air mass meter to mess things up.
Old Nov 5, 2012 | 10:21 AM
Thanks for the reply! Yes, it's k-jet B21f I believe. After a good nights sleep, I've decided I'm gonna run through the usual weak spark culprits before I go chasing fuel issues. Hopefully it's plugs, wires, coil, cap or rotor.
I've read that overly rich fuel/air mixture can cool down spark plugs, causing a mis-fire. Is there any truth to this? And can I check my fuel to air ratio? I do have an lambda o2 sensor, if that helps any.
Old Nov 10, 2012 | 11:39 AM
If it is the fuel pump, whats the best way to verify that?
Old Nov 10, 2012 | 12:02 PM
fuel pressure tester, hooked up via a T inline where hte line fromt he pump goes into the fuel distributor.
Old Nov 10, 2012 | 02:08 PM
Thanks a bunch Pierce! You've been very helpful. I found the problem this morning. After checking the cap, rotor, plugs, wires, I decided to make sure it wasn't low compression. Before starting the compression test I went to disconnect the coil, and found the red/white wire was barely connected, and the spade terminal was covered in black stuff. I could see where it had been sparking across the bad connection. So I cleaned and crimped the connector and now it runs like a dream! Who's idea was it to leave that connector open to the elements? haha, anyways thanks again!
Old Nov 10, 2012 | 04:58 PM
they usually last 25+ years the way they are, at least here on the left coast.
chickade
Mar 2, 2015 06:40 PM
superdoopersauce
Aug 13, 2013 08:25 AM
charlie's70
Sep 28, 2009 08:27 PM
charlie's70
Sep 28, 2009 08:13 PM
Frejborg
Feb 8, 2009 06:25 PM
