1981 wagon DL oil pressure light on
Old Apr 9, 2011 | 11:18 PM
wynd90's Avatar
Default 1981 wagon DL oil pressure light on
Hello!
I just purchased a 1981 DL wagon and the oil pressure light has been on all day (I just bought it this morning). It needs to be taken for an inspection before the insurance can be finalized, but I'm wondering if there are any quick things to check before I get it into the shop as the last owner had only ever seen it on while it was idling.
Any help would be appreciated!
Old Apr 10, 2011 | 07:39 AM
jagtoes's Avatar
Originally Posted by wynd90
Hello!
Well you have one of two possible issues going on here. I assume that you have checked the oil and it is OK. I would think that the low oil pressure switch is bad . I would either replace it or install an oil pressure gauge to verify that it is only the gage and not a problem with the engine. Worse case is that the bearings are bad and you need an engine rebuild. Have the oil pressure checked first.
Old Apr 10, 2011 | 09:22 AM
wynd90's Avatar
Default dually noted!
Ok! I am going to go out and check the wiring to see if that is the issue, and then if not the car will go in the mechanic for further diagnosis. Hopefully it's not as severe as one would think.
Old Apr 10, 2011 | 03:24 PM
swiftjustice44's Avatar
If memory serves me correctly, the oil light wire runs under the crank pulley. Often, the insulation deterioration common in the older cars will cause the wire to ground out. That's assuming your o.p. checks out.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
nuclearseal
Aug 17, 2022 01:48 PM
brettboze
Mar 26, 2012 06:25 PM
wynd90
May 31, 2011 05:19 PM
andybot
Sep 16, 2006 10:59 PM
