1985 volvo 245 cold start after 6 yars
Old May 2, 2019 | 07:53 AM
  #21
jagtoes's Avatar
See this fitting with the small nipple. https://www.ipdusa.com/products/5317...hoCeasQAvD_BwE
Old May 2, 2019 | 08:44 AM
  #22
bunchman's Avatar
Default Nipple
Thank you for your time and input Jagtoes. I followed that link and it says that particular part does not fit my car according to IPD. I'm going to have to do more research.
Old May 11, 2019 | 08:14 AM
  #23
1967 Tempest's Avatar
Any updates?
Old May 16, 2019 | 11:05 AM
  #24
indeed, all volvos from about 83 to mid year 87 have bad wiring harnesses, with insulation that cracks and crumbles under the outer black sheaths. if thats not been addressed, all bets are off. replacement wiring harnesses are model year specific, I believe there's two for an LH car, one for the ignition system, the other for the injection. homebrew repairs (trying to replace individual wires) generally end up a mess.
re that vacuum hose, if indeed, thats the crankcase ventilation / 'flame trap' line, it looks like this...
and the part 7 is 1336681. odds are pretty good the whole oil seperator tank (1) and associated parts (5), (6) should be replaced as the originals are likely brittle and cracked. Genuine Volvo stuffs from dealers like https://www.volvopartswebstore.com/s...roduct=1125815
or aftermarket generic like
Amazon Amazon
(thats parts 5,6,7)
if you replace (1), you probably should also replace o-ring (2)
part (6) is the actual flame trap, this should be cleaned with every oil change for best long term results.
PAVolvo850
Dec 2, 2019 09:17 PM
swordsongs
Dec 17, 2012 11:05 PM
grimvito
Oct 1, 2011 10:06 AM
Alobar
Aug 2, 2010 10:19 PM
rumbel
Aug 25, 2009 06:47 AM
