1985 Volvo 245 DL 2.3L. Any Advice?
Old Feb 6, 2011 | 02:43 AM
MostChameleon's Avatar
Smile 1985 Volvo 245 DL 2.3L. Any Advice?
Ok. Let's get down to business. I have a 1985 Volvo 245 DL T4 2.3L Automatic, and I was wondering if anyone can give me any advice on how to maximize my performance with the B230f (non-turbo) engine without an engine swap? I haven't gone through any other threads, yet, so if there is a familiar one, please post the URL.
Old Feb 6, 2011 | 04:23 PM
swiftjustice44's Avatar
Well, if you want to keep it n/a, a larger free flowing exhaust always helps. The modest M cam in your motor can be swapped for a T cam. The T is stock in turbo motors and usually discarded in favor of a more aggressive cam but it's an improvement in n/a motors. Lots of money? Mill the head to increase compression, port and polish the head, gasket match 'em. Or, you could go turbo. It's called a +T when you turbo an n/a motor. Lots of folks do it but not me. The turbo motors run lower compression so you can add significant boost. To get your 114 hp motor much above 150 hp takes a lot. Hit turbobricks.com and search.
Old Feb 7, 2011 | 07:41 AM
Sounds good, man. I'll see what I can figure out on my end.
Old May 18, 2013 | 02:49 PM
czeben's Avatar
I have a 1985 244 or 245 turbo. It needs a new block. What year of block can I use to replace mine. I plan to keep everything else original.
Thanks,
Chris
DWeston
Apr 5, 2019 04:42 PM
Kodiak351
Feb 1, 2014 10:49 AM
Kodiak351
Nov 20, 2013 07:03 PM
kevindchandler
Sep 27, 2011 06:22 AM
ryans89notch
Sep 15, 2010 08:59 PM
