1986 244 stumbles on cold start, with rough idle
Old Jun 28, 2013 | 12:40 PM
jcporter63's Avatar
Question 1986 244 stumbles on cold start, with rough idle
1986 244 DL, 225K miles. On cold start,the engine stumbles if engine is revved, and may choke and die even on idle. After 5 to 10 minutes, engine smooths out, and will no longer choke on revving.
Diagnostics: Spark is good on all cylinders. Injector delivers on all cylinders. MAF working. Oxy sensor working. When engine is still cold, if I remove the vacuum hose from the fuel pressure regulator, the engine perks up and no longer stumbles.
Diagnostics not done: Cannot do fuel pressure checks (no fittings for gauge).
New or recent parts: New air filter, new cap and rotor. Recent fuel pumps, fuel filter, fuel pump relay (all within the past year).
My initial thought was the fuel pressure regulator. But I'd like to know what ELSE it might be, given the conditions described above. Thanks.
Old Jun 29, 2013 | 12:53 PM
gummed up throttle body or idle air control valve, or the idle microswitch isn't engaging/adjusted properly?
petergreene
Jun 15, 2015 01:53 AM
Mononga
Oct 28, 2012 11:36 AM
Msuperbauer
Aug 31, 2012 10:18 PM
JTK
Feb 14, 2012 07:10 PM
537playing
Oct 26, 2010 08:10 PM
