1987 240 DL start/stall problem
Old Jul 26, 2007 | 06:27 PM
talbott357's Avatar
Default 1987 240 DL start/stall problem
I have just been given a 240 DL Wagon that will start and run for 5 seconds, then stalls out. You can try to give it a little gas when it runs, but it does not change anything as far the engine goes.
I have changed the fuel filter, relay, pressure regulator, and the ECU. The only thing I have not tried is the fuel pump.
Anyone have any ideas?
Old Jul 28, 2007 | 05:37 PM
outofworkjoe's Avatar
Default RE: 1987 240 DL start/stall problem
-rpm or crankshaft position sensor on top of trans, allso power stage on the D/S finder
-radio suppression relay
Old Jul 29, 2007 | 10:09 AM
talbott357's Avatar
Thanks for the info, I will check that out. I did finally get it to run though, it turned out to be a corroded mass air flow sensor. Then it would not start again, this time it was out of fuel.
It goes to show that you should always check the simple things first!!!
jwandhistools
Aug 11, 2009 09:43 AM
shoebox92
Mar 23, 2009 11:24 PM
neartaos
Jan 3, 2009 07:35 AM
mtech25
Dec 8, 2007 07:54 AM
Red XC
May 9, 2006 12:07 AM
