94 850 stall problem after start up
Old May 6, 2006 | 09:23 PM
Red XC's Avatar
Default 94 850 stall problem after start up
My friends 850 had a stall problem after a few mins of driving when the engine is off, tried to restart the engine but will stall right after the start up. Tried to start it back up but only it will crank. Dealer have checked fuel pressure is okay, cleaned throttle body, replaced the battery.
Another tech who worked on the car performed a 120k service. He found a cracked hose near the throttle body he states. But today I found a hose that connects to I believe the PCV cracked and clogged. I replaced that hose but stalling problems still occurs. The stalling after start up only occurs intermittent. The basics were checked, fuel,ignition,vaccum. During the 120k service with the tech, a MIL (check engine light) was on. the tech diagnosis with a EGR problem. But never stated it was repaired!? Today i checked the EGR by adding vacuum to it, engine will run a bit rougher but will not stall. Therefore, the problem wouldn't be the EGR. Any ideas??
Old May 7, 2006 | 01:53 AM
Red XC's Avatar
Default RE: 94 850 stall problem after start up
checked spark again. like before, drive the car for a few mins, stop the car engine off.. wait at least 1 min a few good start ups and most of every check the engine stalls. so I plug in a spark tester. when trying to do the symptom it worked, tester did not light when engine trying to crank. but have spark before it started up.
Old May 7, 2006 | 10:52 AM
Check for codes after it stalls before starting it back up.
Sounds like possibly a Cam sensor. If it all started after the 120k then he might have hit the plug for the Cam sensor. The plugs are known to fall apart.
Old May 7, 2006 | 02:57 PM
Red XC's Avatar
Cam Sensor, hm! Ill check it out. Right now Im still trying to figure out if there is spark when after the motor stalls and re-tries to fire it back up. Well the owner had told me before any service was done to her car that it will sometimes stall when its at a stop sign or traffic light. But will start right back up. Now that problem doesnt happen often or havnt happend to me. Just the stall after startup has occur many times on me rather than the other two techs which didnt take their time to redo the complaint.
Also, there wasnt any codes. Only code was when we disconnected the ECT which gave a DTC of 1-2-3 is false signal. I cleared it, rechecked for codes. Non were found.
Old May 7, 2006 | 03:47 PM
But did you check after the car stalled?
If not try it after it stalls.
Might also need a throttle body and Idle motor cleaning.
Old May 7, 2006 | 04:50 PM
Red XC's Avatar
yeah i checked it after it stalled. non found
TB and idle motor was cleaned at the dealer and charged the customer 225+ .
Old May 7, 2006 | 04:55 PM
Damb!!!
Get a fuel pressure guage and check rest pressure.
Old May 8, 2006 | 01:35 AM
Red XC's Avatar
we checked spark when the stalling occurs, while trying to start. there was spark
tommorow have to drive it to school since i dont have any fuel pressure gauge tools.
tech, should i check it after stalling? when starting.. driving and idle?
Old May 8, 2006 | 01:52 AM
First put the Guage on it and let it sit for a couple of Hours or so. The longer the better.
Before you start it see what the pressure is at. It should drop down some but not lower that 10-20 Psi.
If it goes to 0 then the fuel pump is bad.
That would be almost like changing the fuel filter then starting it. It will start and stall then catch the second or third time.
Old May 8, 2006 | 02:03 PM
Red XC's Avatar
I hope I can check the fuel pressure today and have it sit before starting.
May i ask if the fuel pump lis ocated inside the tank? Just making sure becuz my 245 is located outside next to fuel filter.
Also, is the 850 spark control by the PCM?
Also looking through the fuel rail, in the middle of it below. There is a gold plated and torx screws. It will move while cranking, do you know what that is just for curiosity?
Old May 8, 2006 | 08:50 PM
The fuel pump is in the Tank. Accessed from the trunk or rear of the car.
The PCM tells the coil when to fire after seeing the signal from the Crank sensor,Cam sensor and a few other things.
That I believe is the EGR setup. Cars with EGR are the only ones that have it.
Old May 8, 2006 | 11:53 PM
Red XC's Avatar
Hook up the fuel gauge. the psi was at 45 and dropped about 4psi. But cannot duplicate the stalling to check if any fuel pressure is there.
Old May 9, 2006 | 12:07 AM
How long did it sit for?
Did it sit for as long as it normally does to stall?
I will bet no.
It should have held higher than 4.
alltrades
Feb 14, 2012 11:22 AM
jwandhistools
Aug 11, 2009 09:43 AM
shoebox92
Mar 23, 2009 11:24 PM
neartaos
Jan 3, 2009 07:35 AM
talbott357
Jul 29, 2007 10:09 AM
