1988 240 dl problem
Old Aug 29, 2007 | 05:32 PM
Colibra's Avatar
Default 1988 240 dl problem
So I have an 88' 240 dl and I love it to death. It is having a slight hiccup right now though. I starts fine every time, but when I want to accelerate, it just stalls. Does anyone know what this could be? If I accelerate REALLY slowly then it can build up to a driveable speed, but if I push the accelerator just a little to hard then it dies. Any help would be apprecated. Thanks in advance.
Old Aug 29, 2007 | 07:18 PM
blue goose's Avatar
Default RE: 1988 240 dl problem
How about the basics, check disty cap and ignition wires, vacuum leaks, clogged fuel filter.
Old Aug 30, 2007 | 05:50 PM
JetTech's Avatar
Mine used to do that and come to find out the screen in the fuel tank was full of crud. My car had sat for almost 2 years when I bought it so that explains the problem I had. I removed the tank, cleaned it out, replaced the in-tank fuel pump, and haven't had a problem since.
Old Aug 31, 2007 | 02:42 PM
funnyguy44444's Avatar
First thing I would do is get a new air filter and fuel filter. Also clean out/replace if you want the distributor cap and rotor. Also check your vacuum hoses there are a million of them on old 240s and one unhooked hose can cause a whole slew of problems. I would also go get somw STP or similar fuel system cleaner and run that in you next couple tanks.
Old Aug 31, 2007 | 10:32 PM
VolvoDriver's Avatar
I had issues quite similiar with my 240 a while ago...if i knew then what i do now.
I agree with replacing fuel filter. if you can afford it, replace or upgrade your main fuel pump and intank pump. fuel pimp relay and fuses. also make sure your Air-Mass Meter is not bunk. perhaps your fuel injectors are clogged or leaking. And of course, perform a complete tune up.
Old Sep 1, 2007 | 08:02 PM
Colibra's Avatar
HEy guys, just thought i'd update everyone on the situation. After a guess and check approach to this problem, it seems as I have found it... the Air Mass Meter. I disconnected it and everything seems to be ok. So I am going to the junkyard to see if there is one for cheap and see if I can get an easy cheap fix. Otherwise, I will get a refurbished one from Ebay. Anyway, thanks for all your help guys, it was really appreciated.
jdrrxBrick
Feb 16, 2014 01:31 PM
SPEEDY-RED
Jul 5, 2013 04:00 PM
brooklynaut
Nov 11, 2007 10:46 AM
jhall
May 14, 2006 02:47 PM
Volvo_User
Oct 25, 2003 02:58 AM
