1988 240 emission problem
Old May 11, 2006 | 06:34 PM
jhall's Avatar
Default 1988 240 emission problem
My '88 240DL failed its' emission test because of high NOx (4.7 vs limit of 3.0) The HC and CO were way below their limits. I found that theO2 sensor output voltage was low(..0.1V) and not cycling so I replaced it. No change. I replaced the intake manifold and throttle body gaskets, and checked all the vacuum lines for leaks but still no change. I found that increasing fuel pressure by disconnecting its vacuum line did cause the O2 sensor voltage to cycle normally. Also.disconnecting the air mass meter caused the O2 sensor voltage to go high (steady at about 0.9 volts) Changing the mixture adjustment on the air mass meter had no effect. Any suggestions on getting this lamda system working will be much appreciated. JHall
Old May 11, 2006 | 09:07 PM
Default RE: 1988 240 emission problem
Are you sure it is the correct Mass flow?
Maybe a bad new sensor?
Old May 12, 2006 | 11:12 AM
jhall's Avatar
I'm sure that the air mass meter is the right part no. but I'm not sure it'sgood. I believe the new O2 sensor is OK because it does respond when I cause a rich mixture by increasing the fuel pressure or by disconnecting the air mass meter. Thanks for the fast response. JHall
Old May 12, 2006 | 08:57 PM
I would look at the Mass Flow meter.
We had one a couple of weeks ago that had the wrong Mass Flow.
It ran like Crap. The O2 was pretty much stuck at like 5 Volts. Come to find out it had the wrong Mass Flow sensor installed.
Old May 14, 2006 | 02:42 PM
jhall's Avatar
I didn't think the O2 could go that high. The highest I've ever seen is about 1 volt. JHall
Old May 14, 2006 | 02:47 PM
Sorry meant .500. I always forget about the Decimal point. LOL
jdrrxBrick
Feb 16, 2014 01:31 PM
Colibra
Sep 1, 2007 08:02 PM
tcarp104
Jan 4, 2005 11:48 AM
tkruid
Nov 17, 2004 10:45 PM
VolvoNewbie
Nov 7, 2004 10:21 PM
