1988 740 turbo stall hard restart cold at idle and driving
Old Feb 4, 2014 | 11:26 PM
  #21
huh. my 92 turbo wagon has 225k miles on it, and sounds just fine. but I live where things don't rust
Old Feb 5, 2014 | 08:21 AM
  #22
jagtoes's Avatar
Originally Posted by guest01
Toyota's, Honda's, Mercedes, Sun Beam imp, BMW, Jag's, VW, GM, Ford, +
400k on the engine, Yeah, I've seen it with my own eyes. My turbo wagon has 160k and it sounds like crap, all turbo wagons do. But everything around the engine on these cars goes out;
340K here and live in the northeast . No rust and other then replacing the exhaust system twice and doing normal maintenance we have had no problems.
Attached Thumbnails 1988 740 turbo stall hard restart cold at idle and driving-dsc01557.jpg
Old Feb 5, 2014 | 08:42 AM
  #23
guest01's Avatar
340k w/ with original power stage, MAF, crank sensor, fuel pump relay, water pump gaskets, that water valve at the back of the engine, fuse box blow motor fuse holder burning up, pcv oil trap, intake manifold gasket, voltage regulator. All equal problems.
Yet to see one volvo that didn't need anything other then fluid changes and filters.
Old Feb 5, 2014 | 08:43 AM
  #24
guest01's Avatar
Low friction turbo pistons make noise.
Old Feb 5, 2014 | 11:05 AM
  #25
had 7 volvos, although only 3 were red blocks, 1 did need a MAF for an 850 turbo that my son is now driving, at about 180k miles. never had to replace a power stage, crank sensor. daughter's car (the 400k 87 240) needed a fuel pump relay, oops, no, it was the fuel pump itself, at about 350k miles. my turbo needed the intank pump at about 240k miles, probably got some crappy gas. yes, I've replaced a couple heater valves. water pumps are a ~ 200k mile wear item on most any car I've ever owned. PCV oil traps are a service item, if you don't clean them out periodically, they gum up. alternator brushes are a ~ 250k mile wear item, bundled with the regulator on these bosch alternators. I don't think I've driven any other brand cars that didn't need a new alternator around 250k miles. some sooner.
I can add the radiator on my turbo 740, it was bad at 200k miles. also on the 240, at about 350k it was corroded inside. hoses? sure, standard wear item, typically rarely go past 250k miles on any car i've owned.
you want a maintenance pit? try a early 1990s Mercedes. they consider the engine wiring harness ($800 wholesale, $1200 retail plus 4-5 hours) a wear item. they have enough power steering hoses to plumb a nuclear submarine. rubber flex-discs in the driveshaft that need replacing every 120k or so miles, step 1? drop the entire exhaust system including downpipe and dual(!) cats.
I won't get into my wife's 2004 Toyota Camry... we haven't put more than maintenanceinto it yet but its smoking like a reggae concert at 160k miles, and its had full synth oil changes every 7.5k since new. oh, it just needs valve sleeves? yeah, well the VVTi system makes that a majorly ugly job. the suspension, kind of mushy when new, was totally vague and bouncy at 100k miles, and the steering rack is totally worn out, clunking back and forth. basically, at 10 years and 160k miles, its scrap.
Old Feb 5, 2014 | 10:08 PM
  #26
guest01's Avatar
Cars are money pits in general.
Every car I own needs work.
Old Feb 16, 2014 | 12:08 PM
  #27
guest01's Avatar
I ordered a distributor from autozone and it doesn't fit. wow.
should have just ordered from IPD in the first place.
Anyone have any valid coupon codes????
Old Mar 2, 2014 | 01:37 PM
  #28
guest01's Avatar
I got a reman. from ipd and my car starts. I have not driven it yet, so I"m probably jumping the gun a bit in saying it's fixed just yet. but it wasn't starting at all.
Old Mar 13, 2014 | 07:56 AM
  #29
guest01's Avatar
I drove it a few times with no problems. I'm going to call a distributor a fix.
ijourneaux
Jan 12, 2015 07:53 PM
deary5280
Nov 17, 2011 07:45 PM
jwandhistools
Aug 11, 2009 09:43 AM
Jimal
Mar 27, 2009 04:01 PM
furball3
Jan 28, 2007 03:31 AM
