1989 740 GL will will not start
Old Nov 10, 2007 | 02:34 PM
Captain's Avatar
Default 1989 740 GL will will not start
Please help, my 89 740 volvo cranks but will not start!
Old Nov 10, 2007 | 02:50 PM
Default RE: 1989 740 GL will will not start
Have you checked all the basics?
Fuel
Spark
Injection pulse?
Old Nov 10, 2007 | 04:46 PM
Captain's Avatar
Yes, however, do you think I might need to check the coil, could that be a problem?
Old Nov 10, 2007 | 05:33 PM
tripleb's Avatar
Yes you did check spark, fuel, and the injector pulse?
If you did, then what is missing?
Spark? Is that why you are asking about the coil?
B
Old Nov 13, 2007 | 09:22 AM
basecamper's Avatar
When cranking, do all the warning lights on the dash light up or are any unlit? I ask because on my '87 740, a wire from the alternator had broken (related to the voltage regulator I believe), which prevents the car from starting. The clue was the unlit alternator warning light while cranking. Even if this warning light bulb is burned out, the same no-start condition will prevail.
bigezman
Oct 25, 2011 07:03 PM
steelheaddan
Feb 5, 2011 06:54 PM
740_300K
Nov 30, 2010 06:34 PM
alpine
Aug 12, 2010 04:04 PM
Titan Joe
Jul 2, 2009 10:54 PM
