1990 240DL won't start
Old Oct 15, 2016 | 06:14 PM
otemp14's Avatar
Default ####################
Old Oct 15, 2016 | 07:01 PM
Cwazywazy's Avatar
Hm. Start by checking the battery voltage?
Old Oct 15, 2016 | 11:58 PM
lev's Avatar
lev
Check the coolant level, check the oil level and color, look for signs of milky residue in the oil. If all is well, run the engine monitoring the gauge for 15-20 minutes. No overheating? No lights on? You should be OK.
But, your thermostat may have failed causing the overheating in the first place. A "broken" t-stat would not make the motor run cold, but hot. You may want to change it, it's a cheap part. You can test it, immerse it in hot water, watch it open, etc. Fun!
akpasta
Jan 31, 2013 12:30 PM
aletaaa
Jun 30, 2012 08:29 PM
dustintinsley
Aug 6, 2010 01:13 AM
SPANK
Jul 8, 2009 03:47 PM
perryc516
Sep 27, 2008 07:19 PM
