1990 740 non turbo
Old Feb 24, 2006 | 12:47 PM
pmvictory's Avatar
Default 1990 740 non turbo
Hello,
Having trouble cold starting car. If it's under 30 it will start sputter then if it stays running it will be fine. If it stalls it will not start again. It will turn over but not fire. Had it to the garage they changed rotor plugs etc.. checked the fuel pressure reg. It stays pressurized. They said it could be the idle control motor (valve?) and it will be about 300 to 400 dollars. any ideas
thanks
Pat
Old Feb 24, 2006 | 07:09 PM
igtc's Avatar
Default RE: 1990 740 non turbo
Try to replace your RSR, swap it with your aux fan relay. It will probably be your problem. Been there, done that. This was my fix.
BTW RSR, is your Radio suppression relay. It is one of the two relays attached to the overflow reseviour for your radiator.
Both relays are exactly alike. However, one is for Fuel injectors (RSR), and the other is for your fan in front of your radiator. I removed both, and resoldered them, have yet to have the problem again. I then bought two more from the junkyard, and keep them in my glove box, along with an extra Fuel pump, Bulb out, and K relays for my headlights, just in case I get stuck somewhere.
I've had all these problems, and found in most cases, it is relay related. They get old, and solder joints get cold, and seperate.
Old Feb 24, 2006 | 08:19 PM
Also check the white relay in the fuse box.
See what the date is that is stamped on the side of it. Most of them will only last 5 years.
Old Feb 24, 2006 | 11:30 PM
colgate41's Avatar
Tech is right.....that white relay is the fule pump relay.....and i had problems with it, then i got a new one and my car was fine. I own a 91 740 turbo. Good luck!!!
Old Feb 27, 2006 | 02:31 PM
pmvictory's Avatar
Thanks,
Where are they located?
Pat
Old Feb 27, 2006 | 02:33 PM
pmvictory's Avatar
Thanks tech,
Where would I purchase the white relay?
Pat
Old Feb 27, 2006 | 02:52 PM
colgate41's Avatar
I feel ebay is your best shot for the best price. I got mine for $25, and the volvo dealer wanted $50. Oh the one i got from ebay was brand new as well.
Old Feb 27, 2006 | 03:31 PM
igtc's Avatar
For location, the Fuel Pump (White) relay, the K(silver) relay, and the bulb out (Red Cylindrical), are all behind your ashtray console, under the radio, and behind the fuses.
The fan, and RSR relays (both black) are right next to each other, attached to your radiator overflow tank.
If you are looking for a price & location to purchase; the dealership is Extremely expensive. The junkyard has them, but in some cases, you may have to re-solder these, also. They are also on online auctions (ebay, etc...) is where you can find most, and they are definately in between junkyard, and dealer prices.
cordobe
Dec 1, 2014 06:47 PM
Ablorx
Jul 4, 2014 08:33 PM
craigshensel
Jun 13, 2012 03:11 PM
steelheaddan
Feb 5, 2011 06:54 PM
dads 740 turbo
Oct 13, 2008 03:54 PM
