1990 DL 240 Wagon losing brake fluid
Old Oct 21, 2008 | 10:32 AM
darkdelta's Avatar
Default 1990 DL 240 Wagon losing brake fluid
Hello all,
I am losing brake fluid at a miniscule rate. Nothing on the ground, and I can't see anything in the wheel area to indicate a leak, or the balancing valve (not sure of the terminology here valve between the front brakes and rear brakes). I suspect a/the caliper(s). How bad a job is it to
rebuild them or is replacement a better option?
Old Oct 21, 2008 | 11:41 AM
Default RE: 1990 DL 240 Wagon losing brake fluid
Any wetness around the master cylinder?
Old Oct 22, 2008 | 01:05 PM
darkdelta's Avatar
No apparent leaking around the master cylinder.
Old Oct 22, 2008 | 03:10 PM
OK I wanted to make sure it wasn't the back of the master cylinder leaking.
ibified
Nov 15, 2023 01:59 AM
JWA
May 21, 2014 01:28 PM
EssJay
Aug 8, 2010 11:21 PM
dldunckel
Jan 20, 2010 07:02 PM
Cris
Mar 15, 2008 09:05 AM
