1991 240 AC Not Working and Recent Repair
Old Jun 10, 2011 | 08:15 AM
TwoTonCarmine's Avatar
Default 1991 240 AC Not Working and Recent Repair
I recently had the ignition lock cylinder replaced which involved removing the steering column. The car sat for three weeks while waiting for parts and when the car was returned to me the AC no longer worked. I can hear the compressor click on and off every few seconds but no cool air at all. Before I call back the mechanic I was wondering if there could be a connection between the recent repair and the AC not working. Thanks for any info or thoughts.
Old Jun 10, 2011 | 09:32 AM
jagtoes's Avatar
Did the AC work before you took it for the repair? Usually the symptom of the compressor turning on and off and on and off is due to the low pressure cut out telling you that the freon is low . I can't see replacing the ign. lock as a reason for the AC not to work. I would get a set of AC gages on the system and see what it tells you.
Old Jun 11, 2011 | 04:37 PM
Thanks jagtoes for the response. It is my wife's car and thinking it over it may be that the car lost it's freon before the recent repair. I'll have to have the car checked out, not sure if it needs to be converted in some way to use something other than freon.
vol740wa
Jun 12, 2015 05:02 PM
Rich240
Apr 22, 2015 06:15 AM
richvolvo
May 14, 2013 07:11 PM
gabanja05
Aug 13, 2012 07:22 AM
Gregg
Jul 17, 2010 07:45 AM
