1991 240 Brake Light
Old Sep 15, 2008 | 09:34 PM
smain's Avatar
Default 1991 240 Brake Light
I have been having issues with my passenger side brake lights. A couple years ago, I was having trouble with water flowing into the brake light compartments. I tried drilling a hole in the compartment to drain the water but ended up breaking most of the comparment and having to cover it with lens repair tape. After driving around for a bit, I was pulled over for having a light out and had to replace the entire tail light section. After a couple months, I was pulled over again for having the same light out (even after the replacement). The same process has been repeated about 4 times with the same light. All the while, the light out indicator in the dash remains on. I'm not quite sure how to fix the problem.
Thanks for the help!
Old Sep 15, 2008 | 09:57 PM
Default RE: 1991 240 Brake Light
Check the plug to the tail light good. It might need to be cleaned and the connectors might need to be bent slightly to fit tighter.
s10lowrider1994
Nov 16, 2014 09:27 PM
wobotwalker
Dec 19, 2013 04:37 PM
vipul_vips
Sep 16, 2010 01:30 PM
jeseitz
May 4, 2010 08:42 PM
caliveltz
Feb 19, 2005 08:51 PM
