1991 240 Tail Light Problems
Old Jan 23, 2025 | 05:51 PM
Haruspex's Avatar
Default 1991 240 Tail Light Problems
Hey all,
I recently bought a 1991 240 wagon, the previous owner did inform me on some issues he was having with the tail lights, and I haven't been able to figure out what's causing the problem. I have scoured wiring diagrams and nothing is really jumping out to me so I am posting here in hopes that another 240 owner can help me.
So the problems I'm facing are whenever I press on the brakes, the driver side brake light will simply not turn on if I have no lights on, or will cut power to the brake light if I have my headlights on, same is true for my license plate lights. Then when I have my headlights on and turn my right turn signal on, my tail lights will flash as if they're blinkers but just on the off beat so to speak. I've replaced lights and cleaned contacts on the tail lights.
Any help would be greatly appreciated!
Old Jan 23, 2025 | 08:23 PM
Originally Posted by Haruspex
1991 240 wagon,
If you have a bad (or no) ground to a or both taillamps - those will be your parking/brake/parking/turn/reverse light symptoms.
The tag lights (on a wagon) have problems with the wire harness that goes thru the tailgate hinge. (wires break when bent 90 degree's many times)
Start by making sure (with your $8 test light) that you are getting a 12v signal to each function.
ianharris
Jun 29, 2019 12:02 PM
delsavage
Jan 5, 2017 04:34 PM
Anasanjo
May 19, 2015 09:43 PM
keg22
Mar 13, 2010 06:03 AM
jpravi8tor
Jul 12, 2009 10:35 AM
