1991 745T Mods and Upgrades
Old Sep 24, 2009 | 08:14 PM
  #121
Can be done!!!
Old Sep 24, 2009 | 09:04 PM
  #122
TexFinn's Avatar
Thumbs up
Originally Posted by TIPSP
I finally got around to upgrading the armrest to the "rare" one with the 4 cup holders. It positions your arm in a better, more comfortable way compared to the lower version. I like it so far.
Thanks for posting this. Looks great!
I've had my 86 now for almost 6 days and been wondering if something like can be done. Time go searching for one.
What model is it from?
Old Sep 24, 2009 | 10:16 PM
  #123
TIPSP's Avatar
Got Boost?
Awesome tech your car must be fun on the highway!
I am not sure where the guy got it. I bought this off a turbobrick member.
I can give you the link... I think he still has one left for sale. but the color is not black....
they can be found in the forsale sections of these volvo forums...
Old Oct 19, 2009 | 12:44 AM
  #124
lovely09's Avatar
I'm planning for some upgrades this weekend.I will also change the wheels and looking forward for a repaint.Hope the weather will be good to me to be able to finish all of this.
Old Oct 31, 2009 | 05:08 PM
  #125
TIPSP's Avatar
Got Boost?
F**K me...
had the car towed home on wednesday.
have 60psi compression on the 1st piston. and the 2nd psiton is 0psi (looks like some part of the valve or spring broke). I need to remove the head and check the damage....
F**K...
my life is getting worse and worse. lol.
Old Oct 31, 2009 | 10:09 PM
  #126
Sorry man!!!
Old Nov 1, 2009 | 01:03 AM
  #127
TIPSP's Avatar
Got Boost?
Originally Posted by tech
Sorry man!!!
me too.
Old Nov 1, 2009 | 02:27 AM
  #128
Typhoon's Avatar
I'd say it's the 1-2 cylinder head gasket blow out. Very common. You'll just need to have the head skimmed.
Here's one I prepared earlier!:
By teh way, mine ran well enough to get me 10km home, no overheating etc, just way down on power.
Regards, Andrew.
Old Nov 1, 2009 | 06:43 AM
  #129
Wow! Sorry to hear about the motor problems.
I have alway had a dream of taking a 240 wagon and moding it to be a beast. I want to keep the exterior looking as stock as possible just to keep it "a sleeper".
Your thread has inspired me. Keep up the good work and don't let this little set back get you down.
Old Nov 1, 2009 | 11:00 AM
  #130
TIPSP's Avatar
Got Boost?
It is probably a one two gasket blow out, but when we looked into the spark holes on number two, you can see a valve. We still need to pull the head to see the damage, but look like I might just buy a new head from a local friend....
if it comes down to it, we might just put a rush order at RSI for a Stage1 head (RSI is at a chumpcars 24hours race event though.. they seem to be doing very, very good!) . still have to diagnose this a little more to know for sure. hope there is no piston damage on number 2.... I will post back later.
Hopefully it was just a weak valvetrain, and once new, I can run the same boost levels. we"ll see.......
Old Nov 1, 2009 | 02:04 PM
  #131
TIPSP's Avatar
Got Boost?
Okay...
Just finished talking with a friend of mine. I am buying his head off his project car.
I will pick it up monday, and should have the car running on sunday.
The plus is the head is basicly brand new and it has an IPD turbo cam and gear for a pretty good price!
ordering new gaskets timing belt and spark plugs soon.
Now I still need to pull the head and check what damage is done to the block and pistons.... I pray nothing happened!
I will not run the engine above 3.5rpms anymore. I can't afford this again.
Old Nov 1, 2009 | 04:55 PM
  #132
Hopefully all is well with the pistons.
3500 has nothing to do with it. It was going to happen no matter what RPM you were at.
Old Nov 1, 2009 | 06:17 PM
  #133
TIPSP's Avatar
Got Boost?
maybe...I am sure you're right, but I am scared right now . lol, please don't tempt me
We are also getting some parts for the 240 so it can be safe to drive just incase the 740 needs a new short block.
Old Nov 1, 2009 | 06:23 PM
  #134
Sounds like a plan. Check out the post I made in the sights and sounds. There is a clean 242 in one of the pics.
Old Nov 1, 2009 | 06:29 PM
  #135
TIPSP's Avatar
Got Boost?
I did see it. looked like a nice turn out.
Your car stands out in the crowd!
Old Nov 1, 2009 | 06:30 PM
  #136
Well of course because it is Yellow!! LOL
Old Nov 1, 2009 | 07:58 PM
  #137
TIPSP's Avatar
Got Boost?
And it is sexy... you forgot that.
Old Nov 1, 2009 | 08:01 PM
  #138
OK I guess it is!!!
Old Nov 1, 2009 | 08:28 PM
  #139
TIPSP's Avatar
Got Boost?
Just got done talking with my friend...
turns out he need the car right now, and I can't get his head...
I am still looking. I am going to talk with RSI about their stage one head.
Old Nov 2, 2009 | 05:16 AM
  #140
Typhoon's Avatar
Pull your head and see what's up. You might get away with a valve job, the Volvo heads are pretty sturdy. You could dump a whole lot of money into your head, or another used head, and still be dollars up on an RSI head. Redblock heads are easy to work on, hence cheap to have reconditioned.
As Tech said, rpms don't kill valve trains, wear and old age do. Retainers can just let go, so can valve stems. Actually, excess rpms can cause valve float, but you'd be pushing 6500 rpm on a redblock to find that, and you'd know if you'd experienced valve float!
Let me tell you, I only buy older cars and I romp on all of them once I know they're in good tune. I've never had a catastrophic failure, ever. Stuff just wears out and **** happens sometimes, babying the car won't stop it, it's all about fatigue, load and heat cycles. My Volvo sees 5500 rpm every time it goes out.
Good luck with whatever happens.
Regards, Andrew.
