1992 240 GL intermittent starting issue
Old Nov 20, 2017 | 03:59 PM
swordsongs's Avatar
Default 1992 240 GL intermittent starting issue
Hey Gang!
My beautiful 92 240 GL (standard transmission) has been giving me starting problems. I recently replaced the ignition switch,battery, and starter.
Sometimes the car won't start. It makes the clicking sound and nothing else happens. Usually this happens in the morning. Oddly enough, the thing that always makes it start is if I connect jumper cables to the battery and to another vehicle. The other vehicle must be running for this to work.
Is there a relay causing this? Thanks so much!!
Doug
Old Nov 21, 2017 | 12:58 PM
have you tested the battery and charging system?
my first pass test is to measure the battery cold voltage (after sitting and before trying to crank), if the battery is fully charged it should be about 12.6V at 'room temperature'
then I start the car, and check the battery charging voltage at idle with all accessories switched off, it should be about 1.2V higher than the cold reading.
when you switch on the ignition, the battery/alternator light on the dashboard MUST COME ON. when the engine is started, that light MUST GO OUT (sometimes it takes a throttle blip to make it go out, thats ok). that battery/alternator light is a key part of the alternator charging circuit, it provides the 'bootstrap' current to the alternator field coil via the D+ circuit on the alternator, this allows the alternator to start generating electricity.
if you're not seeing the charging voltage, its quite possible you just need a new voltage regulator, get a real Bosch one, they simply bolt onto the back of the alternator.
Old Nov 22, 2017 | 12:17 AM
swordsongs's Avatar
Thank you Pierce!!
I forgot to mention that I replaced the alternator with an aftermarket one about a year ago. I'll bet that's it!
Best,
Doug
Old Nov 22, 2017 | 02:27 AM
well, before you jump to conclusions, do the tests I described.
steff503
Apr 24, 2016 02:08 PM
Nirky
Jul 29, 2010 02:21 AM
adracoman@hotmail.com
Jul 27, 2010 08:18 PM
algal1
Jan 23, 2010 01:35 AM
