1992 Volvo 240 - Car starts, but electrical systems not working
Here is the background, my 240 started to die while idling or while giving a little gas. After some testing, the fuel rail did not have much pressure. Fuel pumps were working and had correct pressure, I changed the fuel filter. Then the car would start and idle fine. However, none of the electrical is working now.
The car starts just fine. But the headlights, blinkers, gauges, taillights, radio and everything else does not work. I checked the fuses under the dash, and they are all normal. I even rotated and cleaned the fuses and to make sure they had good connections.
I have no clue on what to check next, anyone know what could be causing this? Any advice would be helpful. Thanks.
I'm with you here. I had an ign. switch act intermittently where sometime it would turn on the FP but get no instruments . Juggle the switch and it worked. Had to replace the rear part of the switch . I seem to recall the part cost around $125. The 1st one only lasted for around 200K miles.
volvolongtime
Jun 12, 2015 08:50 AM
LOVEvolvos
May 4, 2013 11:34 PM
