1993 240 wagon No Spark
Old Jan 19, 2018 | 02:37 PM
hansi808's Avatar
Question 1993 240 wagon No Spark
Been helping a friend diagnose her 240 wagon not starting issue. Story has it when we would get a heavy rain here in Hawa'i the car wouldn't start for a day or so then fire back up, then during a recent rain episode the thing just stalled on a hill and hasn't started since. I checked/change the plugs no spark. Moved to the distributor nothing. Coil had power going to it but no spark so we got a new coil...Still nothing. I had read on the forums here about the crank sensors leading to this problem so I pulled that and it had no wire fraying or melting so I assumed this was still good...was that a mistake??
The car wants to start and I feel really close to figuring this out. Any insight or next steps to take would be greatly appreciated.
Mahalos for your time
Old Jan 19, 2018 | 09:07 PM
lev's Avatar
lev
The CPS may be bad even though it may look fine. Change it!
Old Jan 19, 2018 | 10:37 PM
hansi808's Avatar
ok sounds good! thanks lev
...any suggestions on the next step if its not that ?
Old Jan 22, 2018 | 01:37 PM
is the distributor getting wet inside?
is the interior of the car getting condesnation and moisture? (hint would be steamed up windows).
Old Jan 22, 2018 | 03:31 PM
hansi808's Avatar
So I changed the CPS and nothing.
However, upon double checking everything again, im seeing no power to the coil now only from the blue wire on the top. the blue+15... is this telling me the ignition switch is bad? I swear I had volts coming from the +15 last week...car's paying tricks on me
- I also tried the self diagnostic LED thigs and i'm not getting any flashing... in either pin 2 or 6...
- As far as the disty being wet, it is not. Totally dry. We have extreme humidity here in Hawaii but the interior seems pretty dry inside, but moisture is inevitable here...it rains almost every da
Mahalo again for the replys and help! the war continues...
Old Jan 22, 2018 | 05:03 PM
ignition switch is powered by 1-2 heavier gauge red wires from the 'positive terminal', which on a 240 is on the left fender, its a flat black plastic box about the size of a chiclets box, with a bunch of red wires coming out the bottom. the positive terminal, in turn, should be directly connected to the battery + terminal.
Old Jan 22, 2018 | 07:58 PM
Sleipnir's Avatar
Check the error codes to see what comes up. Also, check to see if the crankshaft, camshaft and distributor are all indexed properly.
Sleipnir's Avatar
Oh, and check to see if any one of a number of fuses might be blown.
Old Jan 22, 2018 | 08:29 PM
hansi808's Avatar
Pierce-
Right I'm familiar with that box. So if the ignition switch isn't getting power then the coil will not either...right? And if they (the heavy gauge red wires) are getting power than the ignition switch is bad??
Sleipnir-
Ive tried to check the error codes but get no flashing after turning the ignition to II and holding(or pushing) the button...in either pin 2 or 6... i think it may be faulty.
As far as the fuses go, i cleaned up all the connection sites and replaced all he fuses just for good measure when i started this whole trip.
C-Note jr.
May 3, 2016 01:39 PM
jws
Dec 30, 2011 08:09 PM
dieselsnowmobile
Nov 11, 2011 12:46 PM
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
