1993 240 wagon no start issue.
Old Dec 29, 2023 | 01:22 PM
1993240's Avatar
Default 1993 240 wagon no start issue.
Hi all,
I would appreciate help with a no start issue on my recent acquisitions. 1993 VOLVO 240 WAGON
was starting and running fine, for short time I have had it.
Engine cranks, I am getting spark, I replaced fuel relay, can hear it click on turn of key. Jumped relay connector and both pumps are working, just replaced both at beginning of this issue, hoping that was the problem. Fuses are not blown and I cleaned them up.
where do I look next?
TKS,
MIKE
Old Jan 1, 2024 | 10:45 AM
Psaboic's Avatar
Spray some Starting fluid into the air intake and try to start it. If it fires and even runs for a second or two, you have a fuel delivery issue. If it does not fire or try to run, you have a spark or timing issue. Once you know that, we can go from there.
Old Jan 2, 2024 | 03:17 PM
1993240's Avatar
Tks, I am going to put some time aside this weekend to work on her, I will update with my results.
tks,
Mike
Old Jan 11, 2024 | 07:24 PM
1993240's Avatar
  • Hello 1993240wagon, welcome to the initial stages of our new platform!
    You can find some additional information about where we are in the process of migrating the board and setting up our new software here
    Thank you for being a part of our community!
1993 volvo 240 wagon no start issue.
Unwatch1
1993240wagon
New member
Hi all,
I would appreciate help with a no start issue on my recent acquisitions, a 1993 VOLVO 240 WAGON.
She was starting and running fine, for the short time I have had it.
TKS,
MIKEReply
Report •••
dl242gt
The world of the smiling Dogo
Make sure the timing belt didn't break or slip time. You can remove the oil cap and see if the cam turns. If it does. Check and put the engine at tdc number one cylinder and see if the timing is correct with the belt sprocket. A bad mass air sensor will prevent starting and can flood the engine. Like Reply
Report
  • [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Reactions:Michael921
1993240wagon
New member
dl242gt said:
Make sure the timing belt didn't break or slip time. You can remove the oil cap and see if the cam turns. If it does. Check and put the engine at tdc number one cylinder and see if the timing is correct with the belt sprocket. A bad mass air sensor will prevent starting and can flood the engine.Tks, I will check those things.
The belt was just replaced by previous owner, I already took a quick look and it is indeed new, and tight but I will check timing too.
I will also look at the mass air sensor, if engine was flooded I would assume the plugs would be saturated?Reply
Report •••
Mr. V
Active member
Have you checked for codes? Like Reply
Report1
1993240wagon
New member
Mr. V said:
Have you checked for codes?I have not, I had battery disconnected, so thought they where lost. Would not hurt to check I suppose. Tks.Reply
Report •••
dl242gt
Even if you don't have codes now. It might set one or more trying to start it. You can also run the diagnostic section of the test port and check various sensors on the engine. Like Reply
Report
ZVOLV
<Master Tech>
CLick the no start thread in my sig Like Reply
Report1
1993240wagon
New member
Tks everyone! I am going to work on her some more this weekend, will update with good news I hope.
MikeReply
Report •••1
1993240wagon
New member
MikeSo I replaced the Mass Air sensor and the fuel pressure regulator.
Also the plugs and rotor where shot, gap was at 50, they where so worn and rounded. Replace plugs, wires, rotor and cap as well.
Started right up but now it runs rough for a few minutes then smooths out. The plugs could certainly have played a role but it was running, starting smooth prior. Is it possible a bad MAS senor that flooded the cylinders is causing a residual problem. Maybe the oxygen sensor is fouled? No codes yet, but I only started and let it run a few minutes, 2 times.
I am going to check the timing next.
MikeReply
Report
Old Jan 11, 2024 | 08:22 PM
1993240's Avatar
MikeReply
Old Jan 13, 2024 | 06:18 PM
Psaboic's Avatar
Start it and let it run until the temp gauge shows normal operating temperature. Then shut it off, let it sit for about ten minutes and try restarting it to see how it starts warm/hot. I'm thinking you MAY have a bad engine coolant temperature sensor. These cars have two temperature sensors, one with one wire connected to it that operates the dashboard temperature gauge, and a 2 pin one that sends a temperature signal to the computer for cold and warm fuel mixture adjustment. A good replacement video can be found here
Also, do you know how to read and interpret the codes these cars can set? A great write up can be found here. https://www.volvoclub.org.uk/faq/EngineOBDCodes.html
Good Luck
Old Jan 13, 2024 | 07:27 PM
1993240's Avatar
I will give that a go. I checked for codes, none yet.
hansi808
Jan 22, 2018 08:29 PM
Moq92
Mar 27, 2014 05:10 PM
ankh3000
Aug 6, 2013 08:53 AM
TREMILOW
Jan 20, 2012 07:41 AM
redress
Sep 27, 2011 05:32 PM
