1993 240 Wagon rough/shaky in low gear
Old Jan 14, 2014 | 03:28 PM
nuclearseal's Avatar
Default 1993 240 Wagon rough/shaky in low gear
1993 240 Wagon, B230F head swapped out for older B23 head last winter, barely driven in 2013 because of loud exhaust (didn't have time to fiddle with it), exhaust fixed, runs fine.
Issue is shaky and rough going in first gear (automatic), shifting into second gets better and by third it's all fine.
Hoping for easy fix?
Old Jan 15, 2014 | 01:12 AM
TIPSP's Avatar
Got Boost?
Did you check your fluid level?
Also, do you notice any deceleration noises or vibrations?
Old Jan 15, 2014 | 03:59 AM
also check the center bearing on the driveshaft. the bearing itself can be shot, or the rubber donut it sits in can be worn out, at lower speeds this can cause the driveshaft to rattle around, but it can smooth itself out at higher speeds.
ditto, bad U joints can, under some circumstances, make more audible noises, vibrations at lower speeds.
Old Jan 15, 2014 | 09:51 AM
lev's Avatar
lev
Sounds to me like a low speed engine misfire. You need a tune up first, go from there.
TN240Volvo
Dec 22, 2014 09:06 AM
xingchow
Jun 11, 2013 08:10 AM
cablejohn45
May 14, 2011 05:48 AM
samloz
Oct 15, 2007 07:15 PM
MaT3ka0rA
Jul 27, 2007 04:55 PM
