1993 940 A/C not working?
Hello, i own a 1993 940 sedan 4 door Non turbo well i am having problems with My A/C it has never worked since i bought it from a previous owner it just blows out cool air when turned on but not freezing cold well we decided to get it fixed and took it to a shop for diagnostics and they said that there is no power getting into that tube where you put the frian into when they ran a light tester over it and its an electrical issue so what could be the problem?
Well, I don't know how accurately you are relating the diagnosis you received but if you are, then the shop you went to is really bad.
Is the compressor turning on when jumpered? Is there gas in the system? Good starting points... The panel controller OK?
BTW, vacuuming the system and checking for leaks should cost much less than $500--it's an hour labor...
Sunshine2007
09-26-2012 02:14 PM
