1994 volvo 940
Old Feb 3, 2011 | 09:40 PM
HECTORPORTALUPPI's Avatar
Default 1994 volvo 940
How do i change the headlight lens?
Thank you.
Hector.
Old Feb 3, 2011 | 10:17 PM
do you have the version with separate fog lamps, or just with a single large headlight? is this the US or Euro car (you didn't indicate where you are).
the single large headlight on the US cars at least, has to be swapped as an assembly, the lens is not a separately replaceable item.
Old Feb 4, 2011 | 07:58 PM
swiftjustice44's Avatar
If it's e-code, 4 metal clips hold the lens on. If it's US spec, this is the typical lens replacement...http://cgi.ebay.com/ebaymotors/Volvo...Q5fAccessories
Old Feb 7, 2011 | 09:10 AM
lev's Avatar
lev
True, BUT in reality these pastic lenses "fall off" due to the glue holding them to the housing just drying up. If this is the case you can just reglue it with some silicone; if the lens is broken you can probably still remove it. Getting another NEW lens without the housing is hard (no one sells them), but I see plenty in the junkyards that have come off from the housing.
Old Feb 7, 2011 | 11:34 AM
by the time the lenses fall off, they are usually rather cloudy and yellow.
mchurm
Jan 11, 2010 12:04 PM
hickdead
Aug 9, 2009 02:12 PM
TERRY940
Oct 27, 2008 06:07 PM
funhouse
Sep 5, 2007 05:20 AM
mikkowus
May 20, 2007 05:48 PM
