2004 V70 Water leaking into front passenger side.
Old Apr 4, 2010 | 08:48 PM
jlb1181's Avatar
Default 2004 V70 Water leaking into front passenger side.
I have water leaking into my V70 when the AC is on. There is no visible condensaste dripping from under the car, so I am assuming I have a clogged drain. I have had the car on a lift and cannot find the drain. Can someone clue me in in to where to find the drain tube?
Twice I have lost all electrical to the dash. I had radio and headlights, and not much else. The car ran in a safe mode and made enough power to limp home. I disconnected the positive side of the battery to cross it over to the negative terminal to reset the computer and regain the electrical. When I was back up and running, I had to take it to a mechanic to clear out the SRS error code. I replaced the battery after the first time. I am looking for a possible cause.
Thanks....
Old Apr 8, 2010 | 07:02 PM
jlb1181's Avatar
Discovered the problem with the AC... A bug made its way into the system and plugged the drain tude.
Still guessing on the electrical problem.
Old Apr 8, 2010 | 08:35 PM
Next time on the electrical issue just let the car cool down and see if everything comes back.
I am starting to see alot of the clusters go bad. When the car is cold they work fine. After driving for 15-20 minutes it goes out again.
EmceeCommon
Aug 26, 2013 10:38 PM
Bill Parecki
Dec 18, 2008 12:13 AM
Bill Parecki
Dec 14, 2008 09:16 PM
reidjw
Nov 16, 2008 08:49 AM
stefalfonso19
Jul 22, 2008 03:02 PM
