240 Did I ruin the engine?
Old Aug 22, 2021 | 12:29 PM
teenus's Avatar
Exclamation 240 Did I ruin the engine?
Hello boys and girls! A discalimer here -- this is my first post, this a soft SOS, I am more ape than mechanic. I will share my tale with you, it's winded and likely horrific to the true enthusiests. But my options are limited and the mosquitos are biting so any help from someone with any more volvo experience than me is a major help. That being said, I may have reached the end of the road with my 1984 volvo 244 DL. It's a tan beast. Drove it as my daily for 2 years. 250,000 miles on it. Reliably unreliable. About a month ago, I was driving and the car stalled and slowed to a stop and died on the highway. Tried to jump it, and realized the oil drain plug had fallen off and all the oil litterlly drained out somewhere while i was going a modest 55mph. Got it towed back home, pulled a plug from a 240 at a junkyard, put some new oil in it to see if it would work, checked the coolant and drive belt. It ran for about a week. I was testy with it, took my fiance's car to work that week and rode my bike around but one day decided to go ***** out see if i could drive it to the park. It started making a clanking noise so i truned around after 2 miles or so and the engine overheated stalled and died and no start. Pretty terrfying to see the engine steaming! i freaked. Came back 5 hours later in the evening and it started and made it to the stopsign down the street then died again. Got it towed back to my drive way and its been dead ever since. Just a click, no turn over.
It was having charge problems in June, replaced the alternator. this poor horse it's just fallin apart at the hooves and my lack of expertise leads from one no start to the next.
Is there any way I can test if the engine is completely shot? What are steps to see if I can fix it? What is some advice you all would give? I have looked into Bring - A - Trailer and have debated selling it as it is cosmetically really nice witha couple dings on the exterior. the interior is mostly superb. I live in Nashville, have no garage and the mosqutios thirst for my blood. It's unbearable.
Here is some work i've done in the last year and a half: I've replaced both fuel pumps, battery, starter, radiator, fuses, alternator, distibutor cap and ignition coil.
Ya'll know anyone in Nashville who would come give me an opinion? There's folks at a place called Schnider automotive in Madison, they fixed some fuel line issues a year ago but it was pretty expensive and its far from where I live now and I am a broke musician, covid hasnt helped. Cut my loses? Someone hold me pls. Love this car. If I could fix it somehow, or at least get it to run I would hold onto it longer. Or atleast sell it for much more? I cant replace the engine. I am just a freakin piano player. Help
Love
Shane P.
Old Sep 6, 2021 | 06:02 PM
chaolizi's Avatar
As for no turn over. Put a big socket on the crank bolt and turn it with a long extension bar, if you can't turn it, then the engine locked up, basically no good. (I can turn mine by turning the alternator cooling blades, the engine should not be very hard to turn)
If you can turn it, then your starter might went, use a bar to knock on it and it might run a few times.
Do a compression test if you can get it turn over on its own, wet and dry, if the pressure is shot, then pretty much its gone (IIRC you need 90 something to make a gas engine run, below 120 psi is a sign of bad wearing ). kit is very cheap. But this only tells you about the cylinder condition, if you run it with no oil till died, you are running high chance of damage bearings .
If you got space, you can keep it as a little project, otherwise part out or sell it to someone who needs a good shell.
Wish you good luck.
teenus
Sep 2, 2021 12:17 AM
xDread92x
Nov 7, 2014 01:25 PM
junemann
Jun 4, 2013 09:27 PM
konigstiger1944
Jan 27, 2011 08:15 PM
The newest volvo lover
Jan 24, 2010 03:43 PM
