240 door interchange
pretty sure just about all 240 doors will fit, but if they are TOO old, the trim will be different. 86 or 87 forward and they should be an exact match (blacked out window frame, and so forth). ideally you find one the right color so your car doesn't look like a mongrel... you can swap the interior panels quite easily, and if the donor car doesn't have electric locks, you can swap the lock motor into the door.
