240: high idle in park only
Old Aug 20, 2018 | 04:13 PM
RSV4Rodak's Avatar
Default 240: high idle in park only
Hi all,
Need a little help troubleshooting this one.
Problem: high idle in park only, once warm. Not experiencing this issue in neutral. I've searched and seen mixed responses for problems with park & neutral idle, but not just park.
Any thoughts? Throttle body, idle air control valve?
Thanks
Old Aug 20, 2018 | 04:23 PM
tony1963's Avatar
I will be honest in that I don't know what would be magic about "park" versus "neutral" that would be causing the RPM to rise. However, a high idle can be a vacuum leak.
Old Aug 20, 2018 | 08:56 PM
what year 240? there's at least 3 different fuel injection systems used on the 240 in its 25+ years of production
Old Aug 23, 2018 | 01:55 PM
RSV4Rodak's Avatar
It's a 1990 DL w/ EGR (if that makes a difference).
Also, it now happens in P and N -- but only intermittently. For instance, when I drive the car harder it will idle higher. I will check for vacuum leaks.
Old Aug 23, 2018 | 02:23 PM
240-FAN's Avatar
Cleaning the IACV will help if it hasn't been done before. I had the same issue when I first bought my LH 2.4 244.
Old Sep 6, 2018 | 04:52 PM
RSV4Rodak's Avatar
Thanks for the suggestion. I cleaned the IACV; no luck. Searched for more vaccum leaks and still nothing visible.
I did, however, confirm and isolate the issue... when driving it hard, then putting it into P or N, the idle is high (sometimes, very high).
When driving it easy, the idle is normal, or close to normal.
My guess is replace the IACV?
Old Sep 7, 2018 | 08:32 AM
lev's Avatar
lev
How high is "high"?
Old Sep 10, 2018 | 11:31 AM
RSV4Rodak's Avatar
Unknown, no tachometer. I'd guess it to be double what it should be.
I just noticed a lovely oil leak has increased coming from the front of the engine, near the timing belt. Not sure if that's related to high idle (if it could have an impact on a vacuum leak).
Old Sep 10, 2018 | 12:43 PM
is the oil leak from the top or bottom of the front? if the top, its probably the valve cover gasket, if the bottom, its more likely the camshaft seal.
neither should effect idle speed. air leaks are the #1 cause, things like a hairline crack in the hoses to the IACV. That or the throttle position switch that senses the throttle is at idle. or the throttle body not actually closing completely.
Old Sep 25, 2018 | 12:53 PM
RSV4Rodak's Avatar
Hi Pierce. Oil leak is on the front passenger side of the block; looks like its dripping down on to the front of the exhaust manifold. Valve cover gasket?
Update on the idle: when I turn the car off for a few minutes and then restart it, the idle goes back to normal.
Old Sep 25, 2018 | 01:49 PM
yeah, probably the valve cover gasket then. you can get a UV dye you add to the oil, drive it a short distance, then inspect it with a ultraviolet light in a dark place, you should see exactly where the oil is seeping from
smshnick
Dec 30, 2016 01:08 AM
newmex999
Jun 15, 2014 02:34 PM
sanworker
Oct 2, 2012 06:31 AM
darsunt
Jun 10, 2009 11:48 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
