240 loss of power
Old Sep 11, 2006 | 10:31 AM
soapboxhero's Avatar
Default 240 loss of power
Hi Everyone,
I have a 1982 240 that has been having some problems lately. The one that concerns me most is random loss of power (pick up) that happens when I'm driving for a while. The problem is always accompanied by a rattle/rotating sound (not that loud) from underneath the car. It usually happens like this: I'll be driving for a while (usually at faster speeds), I'll start to hear the rattle/rotate noise from under the car and much of the car's strength is lost. I can't even make it above 45-50 mph.
Then....all of a sudden the noise goes away and the power comes back.
Any ideas?
Thanks in advance.
Old Sep 11, 2006 | 08:58 PM
Default RE: 240 loss of power
Does the tach do anything weird if you have one?
Any other signs with the problem?
Old Sep 11, 2006 | 10:00 PM
There's no tach in the car. By the way, it only happens while I'm pressing on the gas pedal. Then, it stops and my strength is back...no noise.
Old Sep 11, 2006 | 10:02 PM
wojeepster's Avatar
it could possibly be that your catalytic converter has broken up and at times is plugging the exhaust. Tap converter with a rubber hammer and see if you can hear the stuff rattleing around inside.
Old Sep 13, 2006 | 12:03 AM
jfunez's Avatar
ORIGINAL: wojeepster
That sounds very posible....
It also could be spark knock, timming being advanced or retarded by PCM.
Old Sep 13, 2006 | 12:04 AM
jfunez's Avatar
does the check engine light come on?
if so check for codes.
Old Sep 13, 2006 | 07:22 PM
wojeepster's Avatar
82 doesn't have codes.
Old Sep 13, 2006 | 07:26 PM
Thanks guys. I think you're onto something with the cat. The sound does seem to come from under the passenger side. I'll lokk into it.
Old Sep 30, 2006 | 01:44 PM
mjhoesly's Avatar
I have a 91 with the same problem. I just spent 450 dollars & no fix to the problem. Check engine light does come on codes read: TPS, and O2. Please any help!!!
Old Sep 30, 2006 | 02:09 PM
Well...the bad news is that it's not the cat. The good news...I have new mechanic that is great. More bad news....because the problem happens so randomly I can't seem to get him to see it happen. And...from the sound of it, he says it could be really bad. Maybe a loss of oil pressure cauing the pistons to make the rattle noise. And...did I mention I'm always by myself when this happens. Therefore, I can't pull over and hear where the sound is coming from in the engine. (I can't hit the gas pedal while not in the car) Any ideas?
Old Sep 30, 2006 | 04:36 PM
mjhoesly's Avatar
push the throttle cable while under hood, then you can hear the engine.
Wesley brown
Oct 7, 2014 10:12 AM
WhiteVolvoDude
Mar 10, 2013 11:55 PM
the244life
Apr 16, 2010 09:20 AM
Frejborg
Feb 8, 2009 06:25 PM
larwood
Jul 24, 2004 12:32 AM
