240 oil pressure
my 1984 240 turbo is developing oil pressure problems and I was wondering if it has happened to others. 200k+ miles and the oil pressure slowly drops while driving. oil light comes on at red lights, pressure diminishes to 15-20 while driving. I have replaced the oil pump and rod bushings and the problem went away but has returned within 2 months. Scared to drive it. Does this sound familiar to anyone?
Red Blocks rarely need complete overhaul unless they get to many, many more miles... Still, hard to say "never".
I'd eliminate a faulty switch/wiring as the cause but it sounds like the indications are indeed of low oil pressure.
Make sure you are using the correct oil grade, you may want to try a little heavier oil from what you have in there now. If all that doesn't help, take a compression test to determine the overall condition of the motor, go from there...
Thanks, lev, for the feedback. I've already changed out the oil for something heavier, but no real change. Is there anything else that would factor in? New oil pump, new bushings, an inspection of the crank ends finds them within specs, where else might I be losing pressure? IPD suggests that it might be the o-rings between the sump and upper area but noted that in such a relatively simple system, there is little else involved. Is that reasonable?
Thanks for the feedback. looks like o-rings could be the problem. On the off chance it's something else, could the oil sensor (which I have not replaced) or the gauge provide faulty information as described? indicating a slow loss of pressure as the engine warms? Before spending like a sailor for the o-rings....(no offense to the nautically inclined)
Yeah that me was me analogies!!!!! Damn O-rings. One wasn't seated and the other got pinched.
Here is the pic:
![240 oil pressure-oil-fix-1.jpg](https://volvoforums.com/forum/attachments/volvo-240-740-940-12/9014d1483483083t-240-oil-pressure-oil-fix-1.jpg)
My other issue was the feed tube, might want to check that, mine was bent (probably from my own doing) which meant the o-ring wouldn't seat right now matter what I did.
Here is the pic:
![240 oil pressure-oil-fix-2.jpg](https://volvoforums.com/forum/attachments/volvo-240-740-940-12/9015d1483483083t-240-oil-pressure-oil-fix-2.jpg)
bydand
2001-2013 model year XC70
46
10-23-2018 11:11 PM
brettboze
03-26-2012 06:25 PM
thoroughbred
01-15-2008 10:19 AM
