240 possible bad fuel pump
Old Jun 7, 2018 | 05:36 PM
fartoright's Avatar
Default 240 possible bad fuel pump
4 days ago when fuel level was really low car stalled while sitting in drive thru. After sitting for about 5 min it started and ran fine. I filled up. Now today fuel tank is low again and it did the same thing at red light. I let it sit 10 min and started fine drove about 5 min to has station and filled up. Both times it stalled like it was running out of gas, sputtering then finally dying. Is this a sign of bad in tank fuel pump?
Old Jun 7, 2018 | 06:36 PM
could well be.
if this is a 240, its easy to test the pumps. assuming its 1985 or newer, remove fuse 4. take a jumper wire, and connect fuse 6 (either side) to the left side of fuse 4, that should spin the main pump only, you should be able to hear it run under the car. now jumper fuse 6 to the right side of fuse 4, and only the in tank pump should be running... you probably have to open the gas cap and listen with your ear right near the filler pipe to hear it, so using an alligator clip jumper, or a helper is useful.
see In the Tank - 240 Volvo Tank Pump and Sender for *way* too much intel on the transfer (in tank) pump, heh. I wouldn't bother to take one apart and try and fix it, but do note the bit about how too many of the after market fuel sender assemblies are wired backwards, and also many of the aftermarket pumps are basically junk, but some brands are decent (author likes Airtex).
Old Jun 7, 2018 | 07:08 PM
fartoright's Avatar
thanks pierce. I will try jumping fuses tomorrow. Looking at the previous owners detailed maintenance records he never replaced fuel pumps on this 89 and he drove it 15 years and I have been driving it 3 years.
Old Jun 7, 2018 | 11:08 PM
lev's Avatar
lev
As a general rule, not a good idea to starve engines of fuel--causes problems!
Old Jun 7, 2018 | 11:25 PM
the original fuel pumps were very high quality, our 87 lasted probably 20 years and 300K+ miles.
Old Jun 8, 2018 | 03:25 PM
fartoright's Avatar
pierce. Do I leave fuse 6 in when I jump to fuse 4?
Old Jun 8, 2018 | 03:51 PM
yes. fuse 6 is a source of always-on power, its connected directly to the battery.
Old Jun 8, 2018 | 06:06 PM
fartoright's Avatar
pierce, I can definitely hear the main pump under the car but cannot hear anything from pump in tank. Should it be as loud as main pump? Is it easy to hear? I took gas cap off and had my ear right there. I listened before jumping wires and after and nothing. I'm ordering filter and both pumps from IPD tonight. I looked at main pump and it looks like its 1000 years old. Should I get a NEW pump relay? I have a couple used ones from junk yard.
Old Jun 8, 2018 | 06:23 PM
your symptoms are of a bad tank pump. I would only replace that, along with the bit of hose thats inside the tank, and the 'sock' that acts as a fuel pickup inside the tank.
Old Jun 10, 2018 | 09:20 AM
silvermine's Avatar
comprehensive write up about in tank pumps here
Old May 8, 2024 | 02:58 PM
jlf123's Avatar
Originally Posted by pierce
could well be.
I also have a 240 with fuel pump issues but am wondering if it is the relay, not the pump. Does this test bypass the relay?
Old May 9, 2024 | 08:21 AM
act1292's Avatar
Did you check the link? As it states the link has way too much intel on the transfer pump.
Short answer is yes, the test bypasses the relay. Check the link though. It is very informative.
Old Sep 10, 2025 | 01:06 PM
matdeinn3's Avatar
Old Sep 10, 2025 | 07:39 PM
Golden redblock's Avatar
Default Pumps
Yank those pumps out of there!!! Both of them
Goldenblock
240driver
Sep 15, 2025 03:11 PM
edvard
Jul 15, 2022 01:51 AM
rowdy646
Feb 25, 2015 11:24 AM
greaser
Jan 18, 2015 02:06 PM
inilegna
Nov 16, 2013 10:51 AM
