1984 240 - fuel pumps?
Old Dec 26, 2014 | 01:44 PM
rowdy646's Avatar
Default 1984 240 - fuel pumps?
hi I have an 84 240 wagon was running fine then Then just quit fires up with starter spray replaced both pumps and relay and fuses still getting no fuel no noise from pumps even pulled line to check kind of stumped any advice would be much help
Old Dec 26, 2014 | 02:14 PM
time for testing, rather than just replacing things..
p.s just realized you posted this 1984 240 problem on a thread about a 1991 740 Regina, so I'm going to move this to a new thread.
ignore:
first, find and remove the tank pump fuse (its fuse 4 on later ones, but I'm not sure about a 84), and locate the 'clock' fuse (8 on later models) and use a small alligator clip jumper to go between the left clip of the clock fuse (this is ALWAYS POWERED!) to the right clip of the missing tank fuse, WITH THE IGNITION OFF... the tank pump should spin as long as that jumper wire is in place, so go around to the gas cap, remove it, and you should hear that pump humming quietly. now remove that jumper, replace the tank pump fuse, and replace the jumper and BOTH pumps should run, you should hear the main pump humming under the car... maybe some air gurgling through the system til its all flushed back to the tank. if you hear both pumps running, leave the jumper in place and try starting the car... if it starts, then something is still fubar with the fuel pump relay circuit.
edit: in 1984, tank pump is fuse 5, always-on power is fuse 8. your fuse panel might say that fuse 7 is 'main pump', but thats only used on K-Jet cars. LH-II cars do use fuse 13 as the ECU power.... and wait-a-minute, my 1984 diagram doesn't even SHOW a tank pump... so the only fuses are fuse 13 for the ECU (fuel injection control unit), and an inline blade fuse near the left fender for the whole system including fuel pumps.
so, removing fuse 5 does nothing. skip that test. with the ignition off, jumper from the left side of fuse 8 to the left side of fuse 5, and that should power /the/ only fuel pump... you may well hear the fuel gurgling through the system, and certainly should hear the main pump humming.
Old Dec 26, 2014 | 04:16 PM
rowdy646's Avatar
sorry Im new to forums well this car confuses me a bit my paper work says its an 84 240 also it says 245 I followed your instructions in the frist part it defently has 2 pumps and the fuse box had everything you were pointing out and the pumps I put in are brand new so is the relay im still getting no sound from ether pumps thank you for helping me out
Old Dec 26, 2014 | 05:23 PM
AT5 240GL's Avatar
I'm not sure when they changed, but at some point in the 80s Volvo stopped badging the cars with different numbers just using 240 for all. The vin and other spots still make reference to the older numbering system 242 (2 door), 244 (4 door), 245 (wagon). A little confusing but 240 wagon and 245 mean the same thing.
Old Dec 26, 2014 | 05:55 PM
no sound even with the jumper trick?
that bypasses the relay, so its the wiring between the dash and the pumps, or the new pumps themselves are bad.
this car *is* LH-II injection, rigth? all US market 84's should have been LH, but world market cars may still have been KE-Jetronics (aka CIS-E). LH cars have a "AMM" (aka MAF) in the big air hose between the air filter box and the throttle body, and a fuel rail with an electrical connection at each injector, while KE-Jet cars have a fuel distributor assembly, with metal tubes to each injector, and no electrical connections at the injectors.
Old Feb 25, 2015 | 11:24 AM
rowdy646's Avatar
Exclamation ok sorry been a wile i have more funds now working on valvo again
from your discription it is an LH car so i jumped fuse 5 and 8 on the left sides i got the tank pump to run but im geting no sound from the in line pump i went to take off the jumper it sliped and hit other left sides and it started up the tank pump for a second i didnt want to mess with it too much is that normal for the pump to run off other left sides my car has 2 differnt fule relays they are smaller and mount next to each other on the pasenger side under the dash sence i got the pump with the jumper i replaced the relay again yet i sill dont get any pump noise when i turn the key on
mojo
Jan 6, 2013 06:40 PM
BlueBomber
Mar 26, 2011 01:27 PM
hairyg
Jul 15, 2008 12:23 PM
junkmorning
Sep 8, 2006 05:15 PM
whyflygti
Sep 26, 2005 12:42 AM
