240 Tail light wiring
Old Sep 16, 2020 | 02:02 PM
Zlornick's Avatar
Default 240 Tail light wiring
I got a 1990 240 wagon with the driver's side tail light out. All other lights, including driver's side brakes, are fine. Tried swapping the bulb holder, new bulb, etc. Tested for power at the red wire going into the assembly...nothing. checked a little further up the wire... nothing.
Not sure what the next step would be. Looked at the mess of wires going into the fuse box, but there was nothing obvious that jumped out. I'm not even sure if the tail lights feed out of the fuse box.
Any tips would be appreciated.
Old Sep 16, 2020 | 02:27 PM
The parking lights are fused left and right - the two bottom fuses.
If the left front parking light works the fuse is ok (unless someone rigged something)
The rear parking lights, the brake lights (all 3), and the low beam headlamp wiring goes through the bulb out relay - I'm guessing the bulb out light is on. The bulb out relays fail - big round relay under the drivers side of the dash - they usually fail on the brake light circuit, not the parking lights. But you could trace the wire on the taillamp back to the bulb out relay. Sorry, I don't have a wiring diagram to verify the red wire is the correct one.
Old Sep 16, 2020 | 03:42 PM
lets see, 1990 240 wagon USA model,
left tail light...
red - parking light
yellow-grey - brake light
black - reverse light
white - rear fog lamp
black - ground
right tail light...
brown - parking light
yellow - brake light
(white - rear fog lamp on RHD cars only)
black - ground
all light circuits are hot (+12V) if hte light is supposed to be on, or open circuit otherwise. all lights negative side goes to the common taillight ground on that side.
if *ALL* the left rear lights are out, its most likely the ground on that side. on a wagon, the tail lights are grounded to a screw thats below the outer carpet panels on the trunk floor, and just forward of the outer rear corners of the hatch.
Old Sep 16, 2020 | 05:52 PM
Zlornick's Avatar
Ahhhh. Think I got it. Parking light = taillight. Never heard that one, I was assuming parking was referring to the yellow fog light or something. That fuse towards the bottom is blown, so that it's.. I think.
Thanks!!!
Old Sep 16, 2020 | 05:57 PM
well, the tail light is the whole assembly on the tail of the car. the parking lights are the rear lights that come on with the first position on the headlight switch, along with the front corner lights.
fuses only blow when there's a short to ground on that circuit, so if its blown, odds are it will blow again.
Old Sep 16, 2020 | 06:25 PM
Zlornick's Avatar
It's working now. I'll keep my eye on it.
May have blown the fuse fussing with the bulb holder originally. I always have trouble with those things. kinda hate 'em.
I have yet to see the bulb failure light come on in this car. I seem to recall in my old 740/940s that would light up when anything went out. Maybe that relay is something to look at if it goes again.
thanks again.
Old Sep 16, 2020 | 07:20 PM
The black wire at the bulb out relay was commonly cut to eliminate the bulb out light - because people could not figure out what was wrong. It does work - if you use matching bulbs. That is the same exact brake light bulbs, same rear parking light bulbs, same low beam bulbs. The system compares the current that each pair of bulbs uses with a simple technology - a magnetic reed switch is tripped (lighting the bulb out light) if one bulb uses more current than the other.
And notice the two parking light fuses - one powers the tag lamps also, and the other something else (can't remember). Meaning if the cargo door hinge wiring going to the tag lamps breaks - and grounds out it will blow a fuse for whatever side parking lamps it's connected to. Maybe only when you open or close the cargo door.
Old Sep 17, 2020 | 11:40 AM
It's working now.
Or the wiring in the cargo door hinges is broken and grounds out blowing the fuse when the cargo door is opened with the lights on - check for broken wires in the hinges
If the bulb out light did not come on - someone has probably cut the black wire from the relay, because they were tired of seeing the warning and couldn't figure out why it was on
chickade
May 12, 2018 05:33 PM
delsavage
Jan 5, 2017 04:34 PM
jameson
Oct 15, 2015 06:14 AM
thebuellster
Aug 30, 2015 03:18 PM
FCHicks
Dec 12, 2004 11:33 AM
