Tail light issue
Old Aug 29, 2015 | 04:00 PM
thebuellster's Avatar
Default Tail light issue
The other day my left tail light went out, not the brake light, but the running light. These two use the same bulb. when I replaced the bulb I still had the same problem, the brake light working when I hit the brakes but not the regular tail light. I've tried two different bulbs and had the same problem. Anyone know what it might be?
Old Aug 29, 2015 | 05:56 PM
Gazolba's Avatar
If the other tail light is working, I would suspect the wire going into the tail light. I'm sure there is a separate wire for the brakes and the tail light. If you have a wiring diagram for your car, it will probably have the color of the wire.
Old Aug 29, 2015 | 06:29 PM
the left and right tail light are on separate wires all teh way from behind the dashboard where the bulb-out sensor is. that said, the most likely source of a problem is the circuit board on the back of the light assembly, either where the wires plug onto it, or where the socket connects to it. clean the gold surfaces with a clean soft pink pencil eraser, and make sure the contacts on the bulb holder are clean.
Old Aug 29, 2015 | 10:47 PM
Okay I'll give it a shot. Thank you
Old Aug 30, 2015 | 03:18 PM
Ended up being a fuse, that was the first thing I checked but it was dark out so I must have missed it. Thanks for the help
88740gle
Nov 13, 2015 08:13 AM
S60Lover
Apr 3, 2011 11:33 PM
buellfire
Jun 20, 2009 12:37 AM
dgm76513
May 31, 2008 10:53 PM
dgm76513
Nov 11, 2007 05:05 AM
