240 in tank fuel pump wiring
Old Nov 13, 2021 | 10:05 AM
squalus44's Avatar
Default 240 in tank fuel pump wiring
I am replacing my 1990 Volvo in tank fuel pump and I have gotten the assembly out of the tank. While removing the old pump, I stupidly pulled on the wires and partially unspooled the coiled wire from the little carbon(?) cores inside the insulated housing. What do these things do? Are they essential? Can I just bypass them? BTW, I'm sure that others have mentioned this, but the replacement pump had reversed polarity from the original - thankfully, I tested it and discovered this.
Old Nov 13, 2021 | 07:11 PM
jagtoes's Avatar
Sounds like you may have destroyed the wires for the fuel level sensor. If so your fuel gauge will not work.
Old Nov 13, 2021 | 08:49 PM
squalus44's Avatar
Thanks, but the wires for the fuel level sensor are separate and involve a potentiometer. These wires are inside a double tube plastic housing that power the pump.
Old Nov 14, 2021 | 02:10 PM
silvermine's Avatar
you probably have read through this but just in case
In the Tank - 240 Volvo Tank Pump and Sender
MrBric
Dec 18, 2017 03:17 PM
Shaggin240wagon
Oct 6, 2013 12:58 PM
AnEskimo
Jul 30, 2013 01:25 AM
act1292
Dec 21, 2007 08:24 AM
luckytweaker
Jul 21, 2006 05:28 PM
