3&4 only?(blower speeds)
Old Oct 30, 2005 | 01:52 AM
twofourdee's Avatar
Default 3&4 only?(blower speeds)
no 1st or 2nd speeds on my blower, changed the switch and no difference. what next?(89 240 dl)
Old Oct 30, 2005 | 10:32 AM
Default RE: 3&4 only?(blower speeds)
There should be a resistor somewhere on the car.That controls the different fan speeds. I will try to find out where it is.
Old Oct 31, 2005 | 02:36 AM
twofourdee's Avatar
Thanks Tech!
Old Oct 31, 2005 | 08:22 PM
I couldn't find out much today I will see what I can see tomorrow.
Old Nov 5, 2005 | 12:56 PM
twofourdee's Avatar
Any idea as to where the fan speed resistor is located?
Old Nov 5, 2005 | 03:55 PM
Nothing positive but I think is is by the switch.
Old Nov 7, 2005 | 12:34 AM
merian's Avatar
My 745 it is right above the fan motor...but that wasn't the problem with mine, the bushings were seizing in the motor, only higher speeds gave it enough current to turn.
Old Nov 7, 2005 | 09:44 PM
twofourdee's Avatar
Hmmm? I hope its not near the blower motor, it seems like these cars were built around those things. ( long way to get at it properly!)
Old Nov 7, 2005 | 09:45 PM
The resistor is located above the blower motor. From what I am told it is about 6-8 inches long and about 2 inches wide.
You have to pull alot of the dash apart to get to it.
majortomm
Dec 20, 2011 03:42 PM
timwu12
Jan 11, 2010 06:40 PM
s70belgium
Jul 1, 2009 06:05 PM
snkpkp
May 13, 2009 08:52 PM
