s70 blower fan speeds up during braking.
Old Jun 29, 2009 | 12:06 AM
s70belgium's Avatar
Default s70 blower fan speeds up during braking.
What would cause a 99 s70 blower fan to speed up during braking? Letting off the brake pedal, and the fan slows. This happens in either AUTO fan mode, or manual fan mode. Also, I am using the AC, not the heater, I'm in Texas after all. Anybody else ever had or heard of this problem?
Old Jun 30, 2009 | 04:12 PM
Ted1's Avatar
Smile Blower Solution
Mine did the exact same thing. The blower is on it's way out. I got one from a junk yard for $15.00 and problem was solved. Removal/installation simple. Remove glove box and knee bolster and there it is. (I found detailed instructions somewhere on the web but don't remember where)
When it plugged in the replacement it worked fine. Put the old one back, and when I moved it back and forth the speed changed. When you replace it you will be happy to notice more blower power.
If you prefer not to use a junkyard blower you could buy a new one.
Good luck
Old Jul 1, 2009 | 07:28 AM
Also, have you replaced your cabin filter lately?
Old Jul 1, 2009 | 06:05 PM
s70belgium's Avatar
Of note, today when I put the fan control on my car at 100% and vent control for the AC vents, and the air volume from the fan is well below its capacity when new. (It is funny, but as a car ages, we seem to get use to the lower performance of its various parts.)
Yes, I replaced the cabin filter. The old one was very dirty, and now I am wondering if I damaged the fan from overheating. I am going to replace the fan over the holidays and see if all is solved as was suggested. The fan is ten years old anyway.
Thanks for the suggestions/advice.
zpmada
Jul 8, 2012 10:04 AM
91shelby
Feb 18, 2012 03:20 AM
majortomm
Dec 20, 2011 03:42 PM
jimnick
Apr 8, 2011 02:51 PM
twofourdee
Nov 7, 2005 09:45 PM
