740 distributor
Old Oct 26, 2015 | 12:17 PM
tinkerbelle's Avatar
Red face 740 distributor
Ok. I swapped cylinder heads in my 92 740 wagon. It's taken me 6 months because I had to learn as I went. I'm down to the 'easy stuff' I guess,just need a little info. All I have to do is put the distributor on,and the new wires,valve cover gasket, and valve cover. So, I'm just confused over how the distributor should be turned.It's cam-driven,attached to the back of the engine.Do I set the timing marks on the timing belt,etc,then put the distributor on? Which way should the rotor be pointing? By pointing, I mean does the bigger end point up, or the smaller?And since i have a different cylinder head ,does it matter how the camshaft sits in there? I've read that the rotor needs to point to #1 cylinder. How do you make that happen? You can tell I don't know much-it's a wonder i got this far ! I wanna get this thing started before winter. Greatly appreciate generous and detailed info. BTW, my ignition is rex/regina,but my distributor is Bosch.(I know, but it's ok) thank you!!!!
Old Dec 9, 2015 | 07:35 AM
Moved from "New Member".
Old Dec 9, 2015 | 08:43 AM
Why did you even bother replying? What does all that even mean? I posted a legitimate question and I get smart-*** replies or no replies at all. That's ok. I figured it all out myself, with nobody's help and it starts up and drives great. Thanks for nothing everybody.
Old Dec 9, 2015 | 11:39 AM
dytha99's Avatar
Your welcome tinkerbelle.
xaiox20
Apr 5, 2012 03:30 PM
blaine.gross@cox.net
Apr 12, 2011 09:22 PM
iwantansti
Nov 18, 2007 09:16 PM
gman47
Mar 11, 2006 11:16 PM
Volvorator
Mar 3, 2006 09:26 PM
