740 GLE 1986 Instrument cluster connectors
Old Jun 12, 2017 | 02:31 PM
john4ever's Avatar
Default 740 GLE 1986 Instrument cluster connectors
This might sound a bit stupid but while removing the instrument cluster from my 1986 740 some connectors just popped out in the back before I was able to mark them. Most of them would only fit one socket so no problem there, except a small one with two cables only (red/white) which can fit multiple places so not sure where this one should be connected.
The cluster diagram in the manual I have only shows the bigger multi connectors and not this smaller one, I hope someone can help me identify where this one goes (and eventually what it is for would be nice as well)
added photo of the connector here:
https://volvoforums.com/forum/attach...1&d=1497297052
Old Jun 12, 2017 | 02:54 PM
I only have diagrams for 240's, and 1991+ 740/940's, and I know 740 changed the instrument panel in there somewhere so its not the same
Old Jun 14, 2017 | 11:40 PM
lev's Avatar
lev
I think this is a ground wire, (but verify), and goes on the back of the cluster approximately where the tach is. The only other possible male connector is on the back of the speedo.
Old Jun 15, 2017 | 12:36 AM
a red/white wire is usuallythe timing signal right off the ignition coil pin 1, and goes to the tach. brown or brown-white is ground.
on the 1991+ 740/940, that signal is on the "A" 8 pin connector, on pin 6. but I bet a early 740 is completely different
ok, google found this. 1984-1986 volvo 740 wiring diagram, the instrument panel connections.... yeah, white-red or red-white, there's two wires to one connection, and its the tach ('r/min' aka RPM) connection. '85' next to the r/min connector is the speedometer.
Attached Thumbnails 740 GLE 1986 Instrument cluster connectors-1984-1986-volvo-740-instrument-connectors.jpg
Old Jun 15, 2017 | 12:37 AM
and, here's two versions of the 740 instrument panel, yours is probably the bottom one, VDO...
spade lug (1) is the tach connection, red/white wires
spade (4) is +12V power
spade (5) is the speedometer output for the cruise control.
Attached Thumbnails 740 GLE 1986 Instrument cluster connectors-gauge_clusters.jpg
Old Jun 17, 2017 | 03:33 AM
john4ever's Avatar
Many thanks pierce this is great help. I have the top panel in fact (1986 EU model) and I confirm the missing red/white was indeed the tach connection on number 1.
The panel is back on and everything works (except that now I know I need a new engine harness )
OldVolvoboy
Jun 24, 2015 12:52 AM
volvo5volvo
May 29, 2012 05:46 AM
dodgedemon
Mar 27, 2007 10:14 PM
stevemark65
Oct 18, 2006 11:05 AM
jonesje
Jan 9, 2006 08:36 PM
