740 Lift Gate problem
Old Aug 31, 2008 | 10:14 AM
aroger745's Avatar
Default 740 Lift Gate problem
Just bought a 740 wagon, 1992. Lift gate opens from inside, but not with the outside latch. Key turns counterlockwise OK, to lock, but won't turn clockwise to unlock. I have removed the inside hatch trim to expose the mechanism, and it seems clean and tight. Is there a linkage I am missing?> The main link goes up and down with the outside handle, but I cannot release the latch from outside with the key. Chilton is no help - does not show the lliftgate diagram.
Also, does anyone have a diagram of the relays behind the ashtray? My rear wiper and auto locks don't work. Fuses are OK. Chilton no help here either.
Old Sep 4, 2008 | 02:58 PM
cbevis's Avatar
Default RE: 740 Lift Gate problem
maybe your lock cylinder is broken?
Old Sep 4, 2008 | 04:17 PM
billofdurham's Avatar
Relay panel:
[IMG]local://upfiles/4491/C63E6E07F734448EB717824B056AC4A3.jpg[/IMG]
Old Sep 6, 2008 | 10:09 AM
aroger745's Avatar
Thanks for the advice. I have downloaded the Volvo wiring diagrams showing the fuse block and relays. Have also ordered a spare rely for each and every position. My 245 (1988) started to show some flaky electrical problems due to bad relays (high beams and overdrive) plus those #%&@# Bosch bullet fuses that corroded inside the panel. 740 seems to have corrected the electrical problems.
cg23cpo
1998-2000 model year V70
Apr 1, 2013 10:10 AM
coffinberry
Aug 8, 2009 08:02 PM
hfbcballa
Jun 1, 2008 08:29 PM
940turbo94
Dec 1, 2007 01:31 AM
netconcepts
Oct 29, 2007 09:57 AM
