91 240 - Oil Light on - below 2500rpm
Old Sep 7, 2008 | 01:08 AM
sia's Avatar
sia
Default 91 240 - Oil Light on - below 2500rpm
I have had my 91 240 for two years now and the oil light has been on since I bought it. A few months after I bought the car, I noticed the cable to the sending unit was not plugged in. I plugged it in and the light came on. I replaced the sending unit, changed the oil and filter, and this did not fix it. I figured that the previous owner unplugged it since there is seems to be nothing wrong with the car and it runs great. I haven't done anything about it since I figured that it couldn't be the oil pump because it has been running perfectly fine for two years. I recently installed a tachometer and I noticed the light goes off as soon as I hit 2500rpm. I was wondering if anybody has had this problem or if anybody had any idea what the problem could be.
Old Sep 7, 2008 | 02:42 PM
tedv's Avatar
Default RE: 91 240 - Oil Light on - below 2500rpm
You obviously have low oil pressure. When engine is revved up the pressure rises and this makes the light go off. You may have a bad oil pump or generally a worn outengine-not good! The car "runs great", but you are on borrowed time...
Old Sep 7, 2008 | 03:19 PM
sia's Avatar
sia
Thanks a lot for your input. I appreciate your help. I actually called the dealer a few weeks ago and they told me it could be a worn oil pump o-ring. Does that sound like something that could cause this problem?
I highly doubt there is anything major wrong with the engine. The engine idles very smoothly, it accelerates very well, the fuel efficiency is 27mpg city+hwy combined, there is no shaking of any kind, I change the oil every 2500 miles and there has never been any metal fillings in the dirty oil ( I check every time). I have also checked the spark plugs and none of them are damaged or looking abnormal, and I passed emissions with really low numbers.
Old Sep 7, 2008 | 04:27 PM
I have seen many oil pumps not sealed correctly and have the same problem.
Cris van Hoogstraten
Oct 22, 2014 11:50 AM
bowes73
Apr 3, 2013 01:52 PM
greasedlightning
Jul 14, 2010 10:45 PM
BorninBflo
Jun 30, 2008 10:58 AM
gendy
Jul 17, 2006 02:22 PM
